Redis Result Table
Updated on 2024-09-29 GMT+08:00
Function
DLI exports the output data of the Flink job to Redis. Redis is a storage system that supports multiple types of data structures such as key-value. It can be used in scenarios such as caching, event pub/sub, and high-speed queuing. Redis supports direct read/write of strings, hashes, lists, queues, and sets. Redis works with in-memory dataset and provides persistence. For more information about Redis, visit https://redis.io/.
An enhanced datasource connection with Redis has been established, so that you can configure security group rules as required.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
create table dwsSink (
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
with (
'connector.type' = 'redis',
  'connector.host' = '',
  'connector.port' = '',
  'connector.password' = '',
  'connector.table-name' = '',
  'connector.key-column' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. Set this parameter to redis.
connector.host
Yes
Redis connector address
connector.port
Yes
Redis connector port
connector.password
No
Redis authentication password
connector.deploy-mode
No
Redis deployment mode. The value can be standalone or cluster. The default value is standalone.
No
Name of the table stored in the Redis. This parameter is mandatory in the Redis Hashmap storage pattern. In this pattern, data is stored to Redis in hashmaps. The hash key is ${table-name}:${ext-key}, and the field name is the column name.
Table storage pattern: connector.table-name and connector.key-column are used as Redis keys. For the Redis hash type, each key corresponds to a hashmap. A hash key is a field name of the source table, and a hash value is a field value of the source table.
No
This parameter is optional in table storage pattern. The value is used as the value of ext-key in the Redis. If this parameter is not set, the value of ext-key is the generated UUID.
connector.write-schema
No
Whether to write the current schema to the Redis. This parameter is available in table storage pattern. The default value is false.
connector.data-type
No
Data types for storage. This parameter is mandatory for a custom storage pattern. Supported values include string, list, hash, and set. In a string, list or set, the number of schema fields must be 2, and the number of hash fields must be 3.
connector.ignore-retraction
No
Whether to ignore the retraction message. The default value is false.
Precautions
Either connector.table-name or connector.data-type must be set.
Example
  • Configure the table storage pattern when you configure connector.table-name.
    In table storage pattern, data is stored in hash mode, which is different from the basic hash pattern in which the three fields of a table are used as the key, hash_key, and hash_value. The key in table pattern can be specified by connector.table-name and connector.key-column parameters, all field names in the table are used as hash_key, and the field values are written to the hash table as hash_value.
    create table redisSink(
      car_id STRING,
      car_owner STRING,
      car_brand STRING,
      car_speed INT
    ) with (
      'connector.host' = 'xx.xx.xx.xx',
      'connector.port' = '6379',
      'connector.password' = 'xx',
      'connector.table-name'='car_info',
      'connector.key-column'='car_id'
    insert into redisSink
      (car_id,car_owner,car_brand,car_speed)
      VALUES
      ("A1234","OwnA","A1234",30);
  • The following example shows how to create a table when connector.data-type is set to string, list, hash, or set, respectively.
    • String type
      The table contains two columns: key and value.
        attr1 STRING,
        attr2 STRING
      ) with (
        'connector.data-type' = 'string'
        (attr1,attr2)
        VALUES
        ("car_id","A1234");
    • List type
       3
       4
       5
       6
       7
       8
       9
      10
      11
      12
      13
      14
      15
        attr1 STRING,
        attr2 STRING
      ) with (
        'connector.data-type' = 'list'
        (attr1,attr2)
        VALUES
        ("car_id","A1234");
    • Set type
        attr1 STRING,
        attr2 STRING
      ) with (
        'connector.data-type' = 'set'
        (attr1,attr2)
        VALUES
        ("car_id","A1234");
    • Hash type
      The table contains three columns: key, hash_key, and hash_value.
        attr1 STRING,
        attr2 STRING,
        attr3 STRING
      ) with (
        'connector.data-type' = 'hash'
        (attr1,attr2,attr3)
        VALUES
        ("car_info","car_id","A1234");
