Upsert Kafka Result Table
Updated on 2024-09-29 GMT+08:00
Function
DLI exports the output data of the Flink job to Kafka in upsert mode.
Apache Kafka is a fast, scalable, and fault-tolerant distributed message publishing and subscription system. It delivers high throughput and built-in partitions and provides data replicas and fault tolerance. Apache Kafka is applicable to scenarios of handling massive messages.
Kafka is an offline cluster. You have built an enhanced datasource connection to connect Flink jobs to Kafka. You have set security group rules as required.
Precautions
SASL_SSL cannot be enabled for the interconnected Kafka cluster.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
create table kafkaSource(
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
with (
  'connector.type' = 'upsert-kafka',
  'connector.version' = '',
  'connector.topic' = '',
  'connector.properties.bootstrap.servers' = '',
   'format.type' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. Set this parameter to upsert-kafka.
connector.version
No
Kafka version. The value can only be 0.11.
format.type
Yes
Data serialization format. The value can be csv, json, or avro.
connector.topic
Yes
Kafka topic name
Yes
Kafka broker addresses. Use commas (,) to separated them.
connector.sink-partitioner
No
Partitioner type. The value can be fixed, round-robin, or custom.
connector.sink-partitioner-class
No
Custom partitioner. This parameter is mandatory when sink-partitioner is custom, for example, org.mycompany.MyPartitioner.
connector.sink.ignore-retraction
No
Whether to ignore the retraction message. The default value is false, indicating that the retraction message is written to Kafka as null.
update-mode
No
Data update mode. Three write modes are supported: append, retract, and upsert.
connector.properties.*
No
Native properties of Kafka
Example
create table upsertKafkaSink(
  car_id STRING,
  car_owner STRING,
  car_brand STRING,
  car_speed INT,
  primary key (car_id) not enforced
with (
  'connector.version' = '0.11',
  'connector.topic' = 'test-topic',
  'connector.properties.bootstrap.servers' = 'xx.xx.xx.xx:9092',
  'format.type' = 'csv'
