HBase Source Table
Updated on 2023-04-27 GMT+08:00
Function
Create a source stream to obtain data from HBase as input for jobs. HBase is a column-oriented distributed cloud storage system that features enhanced reliability, excellent performance, and elastic scalability. It applies to the storage of massive amounts of data and distributed computing. You can use HBase to build a storage system capable of storing TB- or even PB-level data. With HBase, you can filter and analyze data with ease and get responses in milliseconds, rapidly mining data value. DLI can read data from HBase for filtering, analysis, and data dumping.
  • An enhanced datasource connection has been created for DLI to connect to HBase, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • If MRS HBase is used, IP addresses of all hosts in the MRS cluster have been added to host information of the enhanced datasource connection.
    For details, see Modifying the Host Information in the Data Lake Insight User Guide.
  • You have set up an enhanced datasource connection. For details, see Enhanced Datasource Connections in the Data Lake Insight User Guide.
  • For details about how to configure security group rules, see Security Group Overview in the Virtual Private Cloud User Guide.
Syntax
create table hbaseSource (
  attr_name attr_type
  (',' attr_name attr_type)*
  (',' watermark for rowtime_column_name as watermark-strategy_expression)
with (
  'connector.type' = 'hbase',
  'connector.version' = '1.4.3',
  'connector.table-name' = '',
  'connector.zookeeper.quorum' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. Set this parameter to hbase.
connector.version
Yes
The value must be 1.4.3.
connector. table-name
Yes
HBase table name
Yes
ZooKeeper address
connector.zookeeper.znode.parent
No
Root directory for ZooKeeper. The default value is /hbase.
connector.rowkey
No
Content of a compound rowkey to be assigned. The content is assigned to a new field based on the configuration.
Example: rowkey1:3,rowkey2:3,...
The value 3 indicates the first three bytes of the field. The number cannot be greater than the byte size of the field and cannot be less than 1. rowkey1:3,rowkey2:3 indicates that the first three bytes of the compound rowkey are assigned to rowkey1, and the last three bytes are assigned to rowkey2.
Example
create table hbaseSource(
  rowkey1 string,
  rowkey2 string,
  info Row<owner string>,
  car ROW<miles string, speed string>
 ) with (
   'connector.table-name' = 'carinfo',
   'connector.rowkey' = 'rowkey1:1,rowkey2:3',
   'connector.zookeeper.quorum' = 'xxxx:2181'
