JDBC Source Table
Updated on 2022-07-12 GMT+08:00
Function
The JDBC connector is a Flink's built-in connector to read data from a database.
  • An enhanced datasource connection with the database has been established, so that you can configure security group rules as required.
  • You have set up an enhanced datasource connection. For details, see Enhanced Datasource Connections in the Data Lake Insight User Guide.
  • For details about how to configure security group rules, see Security Group Overview in the Virtual Private Cloud User Guide.
Syntax
create table jbdcSource (
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
  (',' watermark for rowtime_column_name as watermark-strategy_expression)
with (
  'connector.type' = 'jdbc',
  'connector.url' = '',
  'connector.table' = '',
  'connector.username' = '',
  'connector.password' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Data source type. Set this parameter to jdbc.
connector.url
Yes
Database URL
connector.table
Yes
Name of the table where the data to be read from the database is located
connector.driver
No
Driver required for connecting to the database If you do not set this parameter, the automatically extracted URL will be used.
connector.username
No
Database authentication username. This parameter must be configured in pair with connector.password.
connector.password
No
Database authentication password. This parameter must be configured in pair with connector.username.
connector.read.partition.column
No
Name of the column used to partition the input
This parameter is mandatory if connector.read.partition.lower-bound, connector.read.partition.upper-bound, and
connector.read.partition.num are configured.
No
Lower bound of values to be fetched for the first partition
This parameter is mandatory if connector.read.partition.column, connector.read.partition.upper-bound, and
No
Upper bound of values to be fetched for the last partition
This parameter is mandatory if connector.read.partition.column, connector.read.partition.lower-bound, and
No
Number of partitions to be created
connector.read.partition.upper-bound are configured.
connector.read.fetch-size
No
Number of rows fetched from the database each time The default value is 0, indicating the hint is ignored.
Precautions
None
Example
create table jdbcSource (
  car_id STRING,
  car_owner STRING,
  car_age INT,
  average_speed INT,
  total_miles INT)
with (
  'connector.url' = 'jdbc:mysql://xx.xx.xx.xx:3306/xx',
  'connector.table' = 'jdbc_table_name',
  'connector.driver' = 'com.mysql.jdbc.Driver',
  'connector.username' = 'xxx',
  'connector.password' = 'xxxxxx'
