Kafka Source Table
Updated on 2024-09-29 GMT+08:00
Function
Create a source stream to obtain data from Kafka as input data for jobs.
Apache Kafka is a fast, scalable, and fault-tolerant distributed message publishing and subscription system. It delivers high throughput and built-in partitions and provides data replicas and fault tolerance. Apache Kafka is applicable to scenarios of handling massive messages.
Kafka is an offline cluster. You have built an enhanced datasource connection to connect Flink jobs to Kafka. You have set security group rules as required.
Precautions
SASL_SSL cannot be enabled for the interconnected Kafka cluster.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
create table kafkaSource(
  attr_name attr_type
  (',' attr_name attr_type)*
  (','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
  (',' WATERMARK FOR rowtime_column_name AS watermark-strategy_expression)
with (
  'connector.type' = 'kafka',
  'connector.version' = '',
  'connector.topic' = '',
  'connector.properties.bootstrap.servers' = '',
  'connector.properties.group.id' = '',
  'connector.startup-mode' = '',
  'format.type' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. Set this parameter to kafka.
connector.version
Yes
Kafka version. The value can be '0.10' or '0.11', which corresponds to Kafka 2.11 to 2.4.0 and other historical versions, respectively.
format.type
Yes
Data deserialization format. The value can be csv, json, or avro.
format.field-delimiter
No
Attribute delimiter. You can customize the attribute delimiter only when the encoding format is CSV. The default delimiter is a comma (,).
connector.topic
Yes
Kafka topic name. Either this parameter or connector.topic-pattern is used.
No
Regular expression for matching the Kafka topic name. Either this parameter or connector.topic is used.
Example:
'topic.*'
'(topic-c|topic-d)'
'(topic-a|topic-b|topic-\\d*)'
'(topic-a|topic-b|topic-[0-9]*)'
Yes
Kafka broker addresses. Use commas (,) to separated them.
No
Consumer group name
No
Consumer startup mode. The value can be earliest-offset, latest-offset, group-offsets, specific-offsets or timestamp. The default value is group-offsets.
connector.specific-offsets
No
Consumption offset. This parameter is mandatory when startup-mode is specific-offsets. The value is in the 'partition:0,offset:42;partition:1,offset:300' format.
connector.startup-timestamp-millis
No
Consumption start timestamp. This parameter is mandatory when startup-mode is timestamp.
connector.properties.*
No
Native Kafka property
Example
  • Create table kafkaSource and read data encoded in CSV format from Kafka.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
      car_id STRING,
      car_owner STRING,
      car_brand STRING,
      car_speed INT)
    with (
      'connector.version' = '0.11',
      'connector.topic' = 'test-topic',
      'connector.properties.bootstrap.servers' = 'xx.xx.xx.xx:9092',
      'connector.properties.group.id' = 'test-group',
      'connector.startup-mode' = 'latest-offset',
      'format.type' = 'csv'
  • Create table kafkaSource and read data in non-nested JSON strings from Kafka.
    Assume that the non-nested JSON strings are as follows:
    {"car_id": 312, "car_owner": "wang", "car_brand": "tang"}
    {"car_id": 313, "car_owner": "li", "car_brand": "lin"}
    {"car_id": 314, "car_owner": "zhao", "car_brand": "han"}
    You can create the table as follows:
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
      car_id STRING,
      car_owner STRING,
      car_brand STRING
    with (
      'format.type' = 'json'
  • Create table kafkaSource and read the nested JSON data from Kafka.
    Assume that the JSON data is as follows:
        "id":"1",
        "type":"online",
        "data":{
            "patient_id":1234,
            "name":"bob1234",
            "age":"Bob",
            "gmt_create":"Bob",
            "gmt_modify":"Bob"
    CREATE table kafkaSource(
      id STRING,
      type STRING,
      data ROW(
        patient_id STRING,
        name STRING,
        age STRING,
        gmt_create STRING,
        gmt_modify STRING)
    with (
