Condition Expression
CASE Expression
Syntax
1 2 3 |
CASE value WHEN value1 [, value11 ]* THEN result1 [ WHEN valueN [, valueN1 ]* THEN resultN ]* [ ELSE resultZ ] END |
or
1 2 3 |
CASE WHEN condition1 THEN result1 [ WHEN conditionN THEN resultN ]* [ ELSE resultZ ] END |
- If the value of value is value1, result1 is returned; otherwise, resultZ is returned. If there is no else statement, null is returned.
- If the value of condition1 is true, result1 is returned; otherwise, resultZ is returned. If there is no else statement, null is returned.
Precautions
- All results must be of the same type.
- All conditions must be of the Boolean type.
- If the value does not match any condition, the value of ELSE is returned when the else statement is specified, and null is returned when no else statement is specified.
Example
If the value of units equals 5, 1 is returned. Otherwise, 0 is returned.
Example 1:
insert into temp SELECT CASE units WHEN 5 THEN 1 ELSE 0 END FROM Orders; |
Example 2:
insert into temp SELECT CASE WHEN units = 5 THEN 1 ELSE 0 END FROM Orders; |
NULLIF Expression
Syntax
NULLIF(value, value) |
If the values are the same, NULL is returned. For example, NULL is returned from NULLIF (5,5) and 5 is returned from NULLIF (5,0).
Precautions
None
Example
If the value of units equals 3, null is returned. Otherwise, the value of units is returned.
insert into temp SELECT NULLIF(units, 3) FROM Orders; |
COALESCE Expression
Syntax
COALESCE(value, value [, value ]* ) |
Return the first value that is not NULL, counting from left to right.
Precautions
All values must be of the same type.
Example
5 is returned from the following example:
insert into temp SELECT COALESCE(NULL, 5) FROM Orders; |
