ADD COLUMNS
Function
The ADD COLUMNS command is used to add a column to an existing table.
Syntax
ALTER TABLE Table name ADD COLUMNS(col_spec[, col_spec ...])
Parameter Description
Parameter |
Description |
tableName |
Table name. |
col_spec |
Column specifications, consisting of four fields, col_name, col_type, nullable, and comment.
Required Permissions
- SQL permissions
Permission Description |
ALTER permission on a table |
- Fine-grained permission: dli:table:alter
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
alter table h0 add columns(ext0 string); alter table h0 add columns(new_col int comment 'add new column'); alter table delta.`obs://bucket_name0/db0/delta_table0` add columns(new_col string);
Response
You can run the DESCRIBE command to view the new column.
