SDK Overview
This document lists the API opening SDKs of different languages provided by API Gateway and the addresses for obtaining the latest versions.
SDKs
The following table lists the SDKs supported by API Gateway. View the updates, obtain installation packages, and view user guides in GitHub. For details about the APIs, see the ApigClient or apig_client file.
Ensure that you have installed the latest SDKs. Earlier SDKs may not be compatible, or lack the latest features. To query the version, see SDK Center.
If GitHub cannot be visited, check whether you can access the public network.
Language |
GitHub Address |
Reference |
Java |
Python |
Go |
PHP |
Node.js |
