Help Center/ Object Storage Service/ SDK Reference/ Python/ Object-Related APIs (SDK for Python)/ Basic Operations (SDK for Python)/ Downloading an Object (SDK for Python)/ Downloading an Object - Image Processing (SDK for Python)
Updated on 2026-07-31 GMT+08:00
Code Example 1: Creating a Signed URL for Download
This example creates a signed URL for image processing.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 | import os import traceback from obs import ObsClient # Obtain an AK/SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # If you use a temporary AK/SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK/SK pair and a security token to access OBS, you must specify security_token when creating an instance. obs_client = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Name of the bucket that stores the object bucket_name = 'originBucketName' # Object name object_key = 'test.png' query_params = {"x-image-process": "image/resize, w_100"} # Create a signed URL for image processing. res = obs_client.createSignedUrl(method='GET', bucketName=bucket_name, objectKey=object_key, queryParams=query_params, expires=3600) print('signedUrl:', res.signedUrl) except Exception: print(traceback.format_exc()) |
Code Example 2: Performing a Resumable Download
This example processes an image during resumable download.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 | import os import traceback from obs import ObsClient # Obtain an AK/SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # If you use a temporary AK/SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK/SK pair and a security token to access OBS, you must specify security_token when creating an instance. obs_client = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucket_name = "examplebucket" # Object name object_key = "example.png" # Specify the full path to which the object is downloaded. The full path contains the local file name. download_file = './example.png' # Specify the number of parts that can be concurrently downloaded. task_num = 3 # Specify the part size. part_size = 5 * 1024 * 1024 # Enable the resumable download by setting enableCheckpoint to True. enable_checkpoint = True # Specify the image processing parameter. image_process = "image/resize, w_100" # Download the object using resumable download. resp = obs_client.downloadFile(bucket_name, object_key, download_file, part_size, task_num, imageProcess=image_process) # If status code 2xx is returned, the API call succeeds. Otherwise, the API call fails. if resp.status < 300: print('Download File Succeeded') print('requestId:', resp.requestId) else: print('Download File Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except Exception: print('Download File Failed') print(traceback.format_exc()) |
Parent topic: Downloading an Object (SDK for Python)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
