How Do I Obtain an Object URL? (Python SDK)
After setting an ACL to grant anonymous users the read permission for an object in a bucket, you can download this object using its URL. Methods to obtain the object URL are as follows:
Method 1: Query by calling the API. After an object is uploaded by calling ObsClient.putContent or ObsClient.putFile, PutContentResponse is returned. You can call objectUrl to obtain the URL of the uploaded object. Sample code is as follows:
import os
from obs import ObsClient
# Create an ObsClient instance.
obs_client = ObsClient(
access_key_id = os.getenv("AccessKeyID"),
secret_access_key = os.getenv("SecretAccessKey"),
server = 'https://your-endpoint'
resp = obs_client.putContent('bucketname', 'objectname', content='Hello OBS')
if resp.status < 300:
print('requestId:', resp.requestId)
print('objectUrl:', resp.body.objectUrl)
else:
print('errorCode:', resp.errorCode) Method 2: Compose the URL in the format of https://Bucket name.Domain name/Directory level/Object name.
- If the object resides in the root directory of a bucket, its URL does not contain a directory level.
- To view the domain names of each region, see Regions and Endpoints.
- For example, if you want to access the object named test.txt in the test folder of bucket testbucket in the CN-Hong Kong region, the URL for accessing this object is https://testbucket.obs.ap-southeast-1.myhuaweicloud.com/test/test.txt.
