Updated on 2025-05-09 GMT+08:00
Listing Multipart Uploads (SDK for Python)
Function
This API lists ongoing multipart uploads.
Ongoing multipart uploads are the multipart uploads that have been initiated but have not been completed or aborted. A maximum of 1,000 multipart uploads can be returned in a response. If there are over 1,000 ongoing tasks satisfying the list criteria, you need to send more requests to query additional multipart uploads.
Restrictions
  • To list multipart uploads, you must be the bucket owner or have the required permission (obs:bucket:ListBucketMultipartUploads in IAM or ListBucketMultipartUploads in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • To list ongoing multipart uploads in a bucket, you must have the ListBucketMultipartUploads permission.
  • By default, only the bucket owner and multipart upload initiator have this permission. The bucket owner can grant others the ListBucketMultipartUploads permission.
Method
ObsClient.listMultipartUploads(bucketName, multipart, extensionHeaders)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
bucket
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
multipart
ListMultipartUploadsRequest
No
Explanation:
Request parameters for listing multipart uploads. For details, see Table 2.
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
encoding_type
str
No
Explanation:
Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key.
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied to Key.
Table 2 ListMultipartUploadsRequest
Type
Mandatory (Yes/No)
prefix
str
No
Explanation:
Name prefix that the objects in the multipart uploads to be listed must contain
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned.
Restrictions:
The value must contain 1 to 1,024 characters.
Default value:
None
max_uploads
int
or
str
No
Explanation:
Maximum number of listed multipart uploads
Restrictions:
If the specified value is greater than 1000, only 1,000 multipart uploads are returned.
Value range:
An integer from 1 to 1000
Default value:
1000
delimiter
str
No
Explanation:
Object names are grouped by this parameter, which is often used with prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefix. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefix.
Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefix with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefix with abcd as the prefix, and bbcde is grouped separately into another CommonPrefix with bbcd as the prefix.
Value range:
Default value:
None
key_marker
str
No
Explanation:
Object name after which the multipart upload listing begins
Value range:
The value of nextKeyMarker in the response body of the last request
Default value:
None
upload_id_marker
str
No
Explanation:
Upload ID after which the multipart upload listing begins
Restrictions:
This parameter is valid only when used with key_marker. If both parameters are specified, multipart uploads with IDs greater than the specified uploadIdMarker for the specified keyMarker are listed.
Value range:
The value of nextUploadIdMarker in the response body of the last request
Default value:
None
Responses
Table 3 List of returned results
Type
GetResult
Explanation:
SDK common results
Table 4 GetResult
Type
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Table 5 GetResult.body
GetResult.body Type
ListMultipartUploadsResponse
Explanation:
Response to the request for listing multipart uploads
Table 6 ListMultipartUploadsResponse
Type
bucket
str
Explanation:
Bucket name
Restrictions:
  • A bucket name:
Default value:
None
keyMarker
str
Explanation:
Object name after which the multipart upload listing begins, which is consistent with that set in the request.
Value range:
Default value:
None
uploadIdMarker
str
Explanation:
Upload ID after which the multipart upload listing begins, which is consistent with that set in the request
Value range:
The value must contain 1 to 32 characters.
Default value:
None
nextKeyMarker
str
Explanation:
Object name to start with for the next multipart upload listing request. nextKeyMarker is returned when not all the objects are listed. You can set key_marker to this value in the next request to list the remaining multipart uploads.
Value range:
Default value:
None
nextUploadIdMarker
str
Explanation:
Upload ID to start with for the next multipart upload listing request. This parameter is used together with nextKeyMarker. nextUploadIdMarker is returned when not all the objects are listed. You can set upload_id_marker to this value in the next request to list the remaining multipart uploads.
Value range:
Default value:
None
maxUploads
int
Explanation:
Maximum number of listed multipart uploads, which is consistent with that in the request
Restrictions:
Value range:
Default value:
1000
isTruncated
bool
Explanation:
Whether all results are returned in the response
Value range:
  • true: Not all results are returned.
  • false: All results are returned.
Default value:
None
prefix
str
Explanation:
Prefix that the object names in the multipart uploads to be listed must contain. This parameter is consistent with that set in the request.
Restrictions:
Default value:
None
delimiter
str
Explanation:
A character used to group object names in multipart uploads, which is consistent with that set in the request. This parameter is often used with prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes.
Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix.
Value range:
Default value:
None
upload
list of Upload
Explanation:
List of multipart uploads. For details, see Table 7.
Default value:
None
commonPrefixs
list of CommonPrefix
Explanation:
List of object name prefixes grouped according to the delimiter parameter (if specified)
Value range:
Default value:
None
encoding_type
str
Explanation:
Encoding type for key in the response. If key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode key.
Value range:
url
Default value:
Table 7 Upload
Type
key
str
Explanation:
Name of the object to be uploaded. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
Default value:
None
uploadId
str
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8
Value range:
Default value:
None
initiator
Initiator
Explanation:
Initiator of the multipart upload. For details, see Table 9.
Default value:
None
owner
Owner
Explanation:
Owner of the multipart upload, which is consistent with initiator. For details, see Table 10.
Default value:
None
storageClass
str
Explanation:
Storage class of the object to be uploaded
Value range:
See Table 11.
Default value:
None
initiated
str
Explanation:
Time when the multipart upload is initiated
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Sample code: DateTime(year=2023, month=9, day=12)
Default value:
None
Table 8 CommonPrefix
Type
prefix
str
Explanation:
Value range:
Default value:
None
Table 9 Initiator
Type
Mandatory (Yes/No)
id
str
Yes if used as a request parameter
Explanation:
Account (domain) ID of the initiator
Value range:
To obtain an account ID, see Obtaining the Account ID.
Default value:
None
name
str
No if used as a request parameter
Explanation:
Account name of the initiator
Restrictions:
The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Default value:
None
Table 10 Owner
Type
Mandatory (Yes/No)
owner_id
str
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python)
Default value:
None
owner_name
str
Explanation:
Account name of the owner
Value range:
Default value:
None
Table 11 StorageClass
Type
STANDARD
Standard storage class
Explanation:
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
WARM
Infrequent Access storage class
Explanation:
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
COLD
Archive storage class
Explanation:
Used for storing rarely accessed (once a year) data.
Code Examples
This example lists multipart uploads in a bucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
from obs import ObsClient
from obs import ListMultipartUploadsRequest
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName = "examplebucket"
    # Specify the prefix that the object names in the multipart uploads to be listed must contain.
    prefix = 'prefix'
    # Specify the maximum number (10 as an example) of returned multipart uploads. The value ranges from 1 to 1,000. If the value is not in this range, 1,000 is returned by default.
    max_uploads = 10
    # Specify request parameters for listing multipart uploads.
    multipart = ListMultipartUploadsRequest(prefix=prefix, max_uploads=max_uploads)
    # List multipart uploads in a bucket.
    resp = obsClient.listMultipartUploads(bucketName, multipart, encoding_type='url')
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('List Multipart Uploads Succeeded')
        print('requestId:', resp.requestId)
        print('bucket:', resp.body.bucket)
        print('prefix:', resp.body.prefix)
        print('maxUploads:', resp.body.maxUploads)
        print('isTruncated:', resp.body.isTruncated)
        index = 1
        for upload in resp.body.upload:
            print('upload [' + str(index) + ']')
            print('key:', upload.key)
            print('uploadId:', upload.uploadId)
            print('storageClass:', upload.storageClass)
            print('initiated:', upload.initiated)
            print('owner_id:', upload.owner.owner_id)
            print('owner_name:', upload.owner.owner_name)
            index += 1
    else:
        print('List Multipart Uploads Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
