Updated on 2026-07-31 GMT+08:00
Multipart Upload Overview (SDK for Python)
You can upload large files using multipart upload. Multipart upload is applicable to many scenarios, including:
  • Files to be uploaded are larger than 100 MB.
  • The network condition is poor. Connection to the OBS server is constantly down.
  • Sizes of files to be uploaded are uncertain.
A multipart upload consists of the following steps:
  1. Initiate a multipart upload (ObsClient.initiateMultipartUpload).
  2. Upload parts one by one or concurrently (ObsClient.uploadPart).
  3. Assemble parts (ObsClient.completeMultipartUpload) or abort the multipart upload (ObsClient.abortMultipartUpload).
This example shows a complete multipart upload, including initiating a multipart upload, uploading parts, and assembling parts.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
# -*- coding:utf-8 -*-
import os
import traceback
from obs import ObsClient, CompleteMultipartUploadRequest, CompletePart
# Obtain an AK/SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK/SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK/SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obs_client = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    # Bucket name
    bucket_name = "examplebucket"
    # Object name
    object_key = "objectname"
    # MIME type of the object
    content_type = 'text/plain'
    # Initialize a multipart upload task.
    resp = obs_client.initiateMultipartUpload(bucket_name, object_key,
                                             content_type = content_type)
    # Obtain the upload ID of the initialized upload task.
    upload_id = resp.body["uploadId"]
    # Size of the part to be uploaded
    part_size = 512 * 1024 * 1024
    # Part number
    part_num = 1
    # Specify whether object indicates the file path. True is used here. The default value is False.
    is_file = True
    # Local object file to be uploaded
    filepath = r"D:\tmp\file.txt"
    content_length = os.path.getsize(filepath)
    # Start offset of a part in the source file
    offset = 0
    etags = {}
    while offset < content_length:
        part_size = min(part_size, (content_length - offset));
        # Upload parts.
        resp1 = obs_client.uploadPart(bucket_name, object_key, part_num, upload_id, filepath, is_file, part_size, offset)
        etags[part_num] = resp1.body.etag
        offset = offset + part_size
        part_num = part_num + 1
    completes = []
    for i in range(1, part_num):
        completes.append(CompletePart(i, etags[i]))
    # Assemble parts.
    complete_multipart_upload_request = CompleteMultipartUploadRequest(parts=completes)
    resp = obs_client.completeMultipartUpload(bucket_name, object_key, upload_id, complete_multipart_upload_request)
    # If status code 2xx is returned, the API call succeeds. Otherwise, the API call fails.
    if resp.status < 300:
        print('Upload Part Succeeded')
        print('requestId:', resp.requestId)
        print('etag:', resp.body.etag)
    else:
        print('Upload Part Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except Exception:
    print('multPartsUpload Failed')
    print(traceback.format_exc())
Below lists other multipart upload operations:
