Batch Deleting Objects (SDK for Python)
Function
This API deletes objects in a batch from a specific bucket. Deleted objects cannot be restored.
OBS does not involve folders like in a file system. All elements stored in OBS buckets are objects. A folder you see on the console or other tools in OBS is essentially an object whose size is 0 and whose name ends with a slash (/). To delete a folder, you need to list all objects whose names are prefixed with the folder name and then call the batch deletion API.
In a batch delete operation, OBS concurrently deletes the specified objects and returns the deletion result of each object.
Restrictions
- To delete objects in a batch, you must be the bucket owner or have the required permission (obs:object:DeleteObject in IAM or DeleteObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- If versioning is not enabled for a bucket, deleted objects cannot be recovered.
- A maximum of 1,000 objects can be deleted at a time. If you send a request for deleting more than 1,000 objects, OBS returns an error message.
- After concurrent tasks are assigned, if an internal error occurs during cyclic deletion of multiple objects, an object may be deleted in the index data but still exist in the metadata.
Method
ObsClient.deleteObjects(bucketName, deleteObjectsRequest, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| deleteObjectsRequest | Yes | Explanation: Request parameters of deleting objects in a batch For details, see Table 2. Default value: None | |
| extensionHeaders | dict | No | Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
| quiet | bool | No | Explanation: Response mode to the request for deleting objects in a batch Value range:
Default value: False |
| objects | list of Object | Yes | Explanation: List of objects to be deleted. For details, see Table 3. Default value: None |
| encoding_type | str | No | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
| key | str | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| versionId | str | No | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9 Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is deleted. |
| encoding_type | str | No | Explanation: Encoding type for some elements in the response. If delimiter, key_marker, prefix, nextKeyMarker, and key contain control characters that are not supported by the XML 1.0 standard, you can set encoding_type to encode delimiter, key_marker, prefix (including the Prefix in commonPrefixes), nextKeyMarker, and key in the response. Value range: Type: string. Value option: url |
Responses
| Type | Description |
| Explanation: SDK common results |
| Parameter | Type | Description |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| reason | str | Explanation: Reason description. Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server. Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
| GetResult.body Type | Description |
| Explanation: Response results of the request for deleting objects in a batch For details, see Table 7. |
| deleteMarker | bool | Explanation: Whether the deleted object is a delete marker Value range:
Default value: false |
| versionId | str | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9 Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is deleted. |
Code Examples
This example deletes objects objectkey1 and objectkey2 from bucket examplebucket in a batch.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | from obs import ObsClient import os from obs import DeleteObjectsRequest from obs import Object import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify the objects to be deleted in a batch. object1 = Object(key='objectkey1', versionId=None) object2 = Object(key='objectkey2', versionId=None) # Specify encoding_type when the object name contains special characters. encoding_type = 'url' bucketName = "examplebucket" # Batch delete the objects. resp = obsClient.deleteObjects(bucketName, DeleteObjectsRequest(quiet=False, objects=[object1, object2], encoding_type=encoding_type)) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Delete Objects Succeeded') print('requestId:', resp.requestId) if resp.body.deleted: index = 1 for delete in resp.body.deleted: print('delete[' + str(index) + ']') print('key:', delete.key, ',deleteMarker:', delete.deleteMarker, ',deleteMarkerVersionId:', delete.deleteMarkerVersionId) print('versionId:', delete.versionId) index += 1 if resp.body.error: index = 1 for err in resp.body.error: print('err[' + str(index) + ']') print('key:', err.key, ',code:', err.code, ',message:', err.message) print('versionId:', err.versionId) index += 1 else: print('Delete Objects Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Delete Objects Failed') print(traceback.format_exc()) |
This example deletes all objects prefixed with test/ in bucket examplebucket.
In the example below, if the value of prefix is an empty string or NULL, all files in the bucket will be deleted.
import os
import traceback
try:
# Specify the folder to be deleted.
prefix = 'test/'
# Specify the maximum number of objects to be listed at a time. 1000 is used in this example.
max_num = 1000
mark = None
index = 1
failed_list = []
while True:
resp = obsClient.listObjects(bucketName=bucketName, prefix=prefix, marker=mark, max_keys=max_num,
encoding_type='url')
need_to_delete_objects = [Object(key=i["key"], versionId=None) for i in resp.body["contents"]]
del_resp = obsClient.deleteObjects(bucketName,
DeleteObjectsRequest(False, need_to_delete_objects, encoding_type="url"))
for delete in del_resp.body.deleted:
print("Successfully deleted %s " % delete.key)
index += 1
if del_resp.body.error:
for err in del_resp.body.error:
print("Failed to delete %s" % err.key)
failed_list.append(err.key)
if resp.body.is_truncated is True:
mark = resp.body.next_marker
else:
break
else:
break
print("Total deleted %s objects" % index)
for i in failed_list:
print("Failed to delete %s, please try again" % i)
except:
print(traceback.format_exc()) Feedback
