Obtaining the Custom Domain Name of a Bucket (SDK for Python)
Function
This API obtains the custom domain name of a bucket.
Restrictions
- To obtain the custom domain name of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketCustomDomainConfiguration in IAM or GetBucketCustomDomainConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.getBucketCustomDomain(bucketName, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name. Restrictions:
Value range: None Default value: None |
| extensionHeaders | dict | No | Explanation: Extension headers. Restrictions: None Value range: See User-defined Headers. Default value: None |
Responses
| Type | Description |
| Explanation: SDK common result objects |
| Parameter | Type | Description |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| reason | str | Explanation: Reason description Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, this parameter is left blank. The value varies with the API being called. For details, see the sections "Bucket-Related APIs" and "Object-Related APIs". Default value: None |
| GetResult.body Type | Description |
| Explanation: Response result of obtaining the custom domain name of a bucket. For details, see GetBucketCustomDomainResponse. |
| domains | list of Domain | Explanation: The bucket's custom domain name list. Value range: For details, see Domain. |
| name | str | Explanation: Name of the certificate bound to the custom domain name. Value range: The value is a string of 3 to 63 characters. |
| domain_name | str | Explanation: Custom domain name. Value range: The value is a string of 0 to 256 characters. |
| create_time | str | Explanation: Time when a custom domain name was created. Value range:
| certificate_id | str | Explanation: ID of the certificate bound to the custom domain name. Value range: The value is a string of 16 characters. |
| certificateType | str | Explanation: Type of the certificate bound to the custom domain name. Value range:
| expiredTime | str | Explanation: If the certificate type is server or server_sm, the expiration time of the certificate bound to the custom domain name is returned. Value range: The value must be a UTC time that complies with the ISO 8601 standard. Example: 2018-01-01T00:00:00.000Z |
Code Examples
This example obtains the custom domain name of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 | import os import traceback from obs import ObsClient # Obtain an AK/SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # If you use a temporary AK/SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK/SK pair and a security token to access OBS, you must specify security_token when creating an instance. obs_client = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucket_name = "examplebucket" # Obtain the custom domain name of the bucket. resp = obs_client.getBucketCustomDomain(bucket_name) # If status code 2xx is returned, the API was called successfully. Otherwise, the call failed. if resp.status < 300: print('Get Bucket CustomDomain Succeeded') print('requestId:', resp.requestId) for domin in resp.body.domains: print('domainName:', domin.domainName) print('createTime:', domin.createTime) else: print('Get Bucket CustomDomain Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except Exception: print('Get Bucket CustomDomain Failed') print(traceback.format_exc()) |
Helpful Links
