Deleting Bucket Tags (SDK for Python)
Function
If you add tags to a bucket, SDRs generated for the requests sent to this bucket will include these tags, so you can use the tags to classify SDRs for detailed cost analysis. For example, if you have an application that uploads its running data to a bucket, you can tag the bucket with the application name. In this manner, the costs on the application can be analyzed using tags in SDRs.
This API deletes the tags of a bucket.
Restrictions
- To delete bucket tags, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucketTagging in IAM or DeleteBucketTagging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
 - The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.deleteBucketTagging(bucketName, extensionHeaders)
Request Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        bucketName  |
        String  |
        Yes  |
        Explanation: Bucket name Restrictions:
 Default value: None  |
        extensionHeaders  |
        dict  |
        No  |
        Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None  |
Responses
        Type  |
        Description  |
        Explanation: SDK common results  |
        Parameter  |
        Type  |
        Description  |
        status  |
        int  |
        Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None  |
        reason  |
        str  |
        Explanation: Reason description. Default value: None  |
        errorCode  |
        str  |
        Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None  |
        errorMessage  |
        str  |
        Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None  |
        requestId  |
        str  |
        Explanation: Request ID returned by the OBS server Default value: None  |
        indicator  |
        str  |
        Explanation: Error indicator returned by the OBS server. Default value: None  |
        hostId  |
        str  |
        Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None  |
        resource  |
        str  |
        Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None  |
        header  |
        list  |
        Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None  |
        body  |
        object  |
        Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None  |
Code Examples
This example deletes tags of bucket examplebucket.
        1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32  |
        from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName="examplebucket" # Delete bucket tags. resp = obsClient.deleteBucketTagging(bucketName) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Delete Bucket Tagging Succeeded') print('requestId:', resp.requestId) else: print('Delete Bucket Tagging Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Delete Bucket Tagging Failed') print(traceback.format_exc())  |
