Help Center/Object Storage Service/SDK Reference/Python/Bucket-Related APIs (SDK for Python)/Configuring Lifecycle Rules for a Bucket (SDK for Python)
Updated on 2026-01-06 GMT+08:00
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API configures lifecycle rules for a bucket.
  • Expired objects will be permanently deleted and cannot be recovered.
  • Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
  • The minimum storage duration is 30 days for Infrequent Access storage, and 90 days for Archive storage. After an object is transitioned to the Archive storage class, if it stays in this storage class for less than 90 days, you still need to pay for a full 90 days.
Restrictions
  • There is no limit on the number of lifecycle rules in a bucket, but the total size of XML descriptions about all lifecycle rules in a bucket cannot exceed 20 KB.
  • A maximum of 20 lifecycle rules can be configured for a parallel file system.
  • To configure a lifecycle rule for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutLifecycleConfiguration in IAM or PutLifecycleConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketLifecycle(bucketName, lifecycle, extensionHeaders)
Request Parameters
Type
Mandatory (Yes/No)
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
lifecycle
Lifecycle
Yes
Explanation:
List of lifecycle rules. For details, see Table 1.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Headers (SDK for Python).
Default value:
None
Table 1 Lifecycle
Type
Mandatory (Yes/No)
rule
list of Rule
Yes
Explanation:
List of lifecycle rules. For details, see Table 2.
Default value:
None
Table 2 Rule
Type
Mandatory (Yes/No)
id
str
No
Explanation:
Lifecycle rule ID
Value range:
The value must contain 1 to 255 characters.
Default value:
None
prefix
str
Yes
Explanation:
Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket.
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg only. If you set Prefix to logs/, the rule applies to the three objects with name starting with logs/. If you leave Prefix blank, the rule applies to all objects in the bucket.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
status
str
Yes
Explanation:
Whether the rule is enabled
Value range:
  • Enabled
  • Disabled
Default value:
None
transition
Transition
or
list of Transition
No
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 3.
Restrictions:
This parameter applies only to the current object version.
Default value:
None
expiration
Expiration
No
Explanation:
Object expiration time. For details, see Table 4.
Restrictions:
Default value:
None
noncurrentVersionTransition
NoncurrentVersionTransition
or
list of NoncurrentVersionTransition
No
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 7.
Restrictions:
  • This parameter applies only to noncurrent object versions.
  • Versioning is enabled (or suspended after being enabled) for the bucket.
  • This parameter is not available for parallel file systems.
Default value:
None
noncurrentVersionExpiration
NoncurrentVersionExpiration
No
Explanation:
Expiration time of noncurrent object versions. For details, see Table 8.
Restrictions:
CAUTION:
Default value:
None
Table 3 Transition
Type
Mandatory (Yes/No)
storageClass
str
Yes if used as a request parameter
Explanation:
Storage class of the object after transition
Restrictions:
  • The Standard storage class is not supported.
  • Restrictions on storage class transitions:
    • Only transitions from the Standard storage class to the Infrequent Access storage class are supported. To transition objects from Infrequent Access to Standard, you must manually do it.
    • Only transitions from the Standard or Infrequent Access storage class to the Archive storage class are supported. To transition objects from Archive to Standard or Infrequent Access, you must restore the objects first and then manually transition their storage class.
Value range:
See Table 5.
Default value:
None
date
str
or
DateTime
Yes if the parameter is used as a request parameter and days is absent
Explanation:
OBS executes the lifecycle rule for objects that were modified before the specified date.
Restrictions:
The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are transitioned to the specified storage class.
For example, DateTime(year=2023, month=9, day=12)
Default value:
None
days
int
Yes if the parameter is used as a request parameter and date is absent
Explanation:
Number of days (since the last update was made to the object) after which the lifecycle rule takes effect
Restrictions:
Value range:
An integer greater than or equal to 0, in days
Default value:
None
Table 4 Expiration
Type
Mandatory (Yes/No)
date
str
or
DateTime
Explanation:
Restrictions:
The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are deleted.
Default value:
None
days
int
Explanation:
Restrictions:
Value range:
Default value:
None
Table 5 StorageClass
Type
STANDARD
Explanation:
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
WARM
Explanation:
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
COLD
Explanation:
Used for storing rarely accessed (once a year) data.
INTELLIGENT_TIERING
Intelligent Tiering
Explanation:
Is designed to optimize storage costs by automatically moving data to a more economical access tier when data access patterns change. This storage class is ideal for data with constantly changing or unpredictable access patterns.
Table 6 DateTime
Type
year
int
Explanation:
Year in UTC
Default value:
None
month
int
Explanation:
Month in UTC
Default value:
None
day
int
Explanation:
Day in UTC
Default value:
None
hour
int
Explanation:
Hour in UTC
Restrictions:
The value is in 24-hour format.
Default value:
0
min
int
Explanation:
Minute in UTC
Default value:
0
sec
int
Explanation:
Second in UTC
Default value:
0
Table 7 NoncurrentVersionTransition
Type
Mandatory (Yes/No)
storageClass
str
Explanation:
Storage class of noncurrent object versions after transition
Restrictions:
Value range:
See Table 5.
Default value:
None
noncurrentDays
int
Explanation:
Number of days an object is noncurrent before the specified rule takes effect
Restrictions:
Value range:
Default value:
None
Table 8 NoncurrentVersionExpiration
Type
Mandatory (Yes/No)
noncurrentDays
int
Explanation:
Restrictions:
Value range:
Default value:
None
Responses
Type
GetResult
Explanation:
SDK common results
Table 9 GetResult
Type
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Code Examples
This example configures a lifecycle rule for bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
from obs import ObsClient
from obs import Expiration, NoncurrentVersionExpiration
from obs import DateTime
from obs import Rule
from obs import Lifecycle
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    # Configure a lifecycle rule for deleting objects with prefix1 as the prefix after 60 days since the last update.
    rule1 = Rule(id='rule1', prefix='prefix1', status='Enabled', expiration=Expiration(days=60))
    # Configure a lifecycle rule for deleting objects with prefix2 as the prefix on December 31, 2023.
    rule2 = Rule(id='rule2', prefix='prefix2', status='Enabled', expiration=Expiration(date=DateTime(2023, 12, 31)))
    lifecycle = Lifecycle(rule=[rule1, rule2])
    bucketName="examplebucket"
    # Configures the lifecycle rules for the bucket.
    resp = obsClient.setBucketLifecycle(bucketName, lifecycle)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Set Bucket Lifecycle Succeeded')
        print('requestId:', resp.requestId)
    else:
        print('Set Bucket Lifecycle Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
