Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
Help Center/ Object Storage Service/ SDK Reference/ Python/ Downloading and Installing OBS SDK for Python
Updated on 2024-04-23 GMT+08:00
This topic provides the download links and installation methods of OBS SDK for Python.
Downloading OBS SDK for Python
Latest version of OBS Python SDK source code: Download
You can use the methods listed in Table 1 to install OBS SDK for Python.
Method 1: (Recommended) Installing the SDK Using pip
  1. Run the pip -V command to check the pip version and ensure that pip is installed.
  2. Run pip install esdk-obs-python --trusted-host pypi.org to start the SDK installation.
  • If pip has not been installed, install it following the instructions on the pip official website.
  • In a Windows operating system, the message "Not internal or external command" is displayed when you run the pip command. In this case, add the pip installation directory (generally the Scripts folder in the directory where the Python is located) to the Path environment variable.
  • You may need to restart the computer for the environment variables to take effect.
Method 2: Installing the SDK Using the Source Code
The following procedures show an example of installing the latest version of OBS Python SDK.
  1. Download the SDK package and decompress it.
  2. Run pip install pycryptodome==3.10.1 to install the cryptographic library.
  3. Decompress the development package to obtain folder src (SDK source code), folder examples (sample code), file README.txt (feature description file of SDK versions), and file log.conf (SDK log configuration file).
  4. Use PyCharm to create a project, copy the folders and files obtained in the previous step to the project, right-click folder src, and choose Mark Directory as > Sources Root.
    After the configuration, the directory structure is similar to the following:
    ├── examples
    ├── src
    ├── log.conf
    └── README.md
Method 3: Installing the SDK Using setuptools
  2. Download and install setuptools.
  3. On the command-line interface (CLI), go to folder src under the directory where the development package is decompressed.
  4. Run the python setup.py install command to install the SDK.
  5. After the installation, check whether a folder named esdk_obs_python-<versionId>-*.egg is generated in Lib/site-package under the Python installation directory.
    • If you use this method to install the SDK, you need to delete folder esdk_obs_python-<versionId>-*.egg when you re-install the SDK.
    • If SDK modules cannot be loaded after you have performed the previous steps, you can directly add the absolute path of the src directory in OBS Python SDK to the sys.path list.
