Updated on 2026-09-20 GMT+08:00
Truncating an Object (SDK for Node.js)
Function
This API is used to truncate an object in a bucket to a specified size.
Restrictions
Method
ObsClient.truncateObject(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Name of a file object. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
Length
number
Yes
Explanation:
Size of the object after the truncation, in bytes.
Restrictions:
N/A
Value range:
0 to 54975581388800 (50 TB)
Default value:
N/A
Responses
Table 2 Responses
Type
Table 3
Explanation:
Returned results. For details, see Table 3.
This API returns a Promise response, which requires the Promise or async/await syntax.
Table 3 Response
Type
CommonMsg
Table 4
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results returned for a successful call. For details, see Table 5.
Restrictions:
This parameter is left blank if the value of Status is greater than 300.
Table 4 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 InterfaceResult
Type
RequestId
string
Explanation:
Sample Code
You can call ObsClient.truncateObject to truncate an object. The sample code is as follows:
// Import the OBS library.
// Use npm for installation.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code for installation.
// var ObsClient = require('./lib/obs');
// Create an ObsClient instance.
  // Obtain an AK and SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function truncateObject() {
  try {
    const params = {
      // Specify a bucket name.
      Bucket: "examplebucket",
      // Specify an object name.
      Key: "objectname.txt",
      // Specify the size of the object after the truncation, in bytes.
      Length: 1024,
    // Truncate an object.
    const result = await obsClient.truncateObject(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Truncate object successful!\n");
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
truncateObject();
