Configuring an Online Decompression Policy (SDK for Node.js)
Function
OBS can automatically decompress uploaded ZIP packages and save them to a specified directory. If any ZIP package uploaded to a bucket matches the configured decompression policy, the package will be automatically decompressed to the specified directory. This API is used to configure a ZIP file decompression policy for a specified bucket. For more information about online decompression, see Online Decompression.
Online decompression is not available for fusion buckets.
Restrictions
Permissions
- To configure, obtain, or delete online decompression policies, you must have the Tenant Administrator permission assigned by using role/policy-based authorization of IAM.
- Online decompression requires that you create an IAM agency to delegate OBS to access data in the bucket. The permissions the agency should assign to OBS include obs:object:PutObject, obs:object:GetObject, and obs:object:AbortMultipartUpload.
Package and file size
- A single ZIP package cannot exceed 1 GB in size.
- A single ZIP package can contain a maximum of 65,536 files.
- A single decompressed file cannot exceed 40 GB in size.
Time
- Decompressing a ZIP package takes 10 minutes at most.
Functions
- Currently, only ZIP packages are supported.
- ZIP package names cannot contain Chinese punctuation marks, special characters, or special codes such as \/:*?"<>|@#¥.
- To decompress the ZIP package that contains other ZIP packages, the event type of the online decompression policy must be set to ObjectCreated:* or ObjectCreated:CompleteMultipartUpload.
- Currently, no notification will be sent to users after decompression tasks are complete.
- Currently, only deflate-compressed ZIP packages can be decompressed. Deflate is different from the compression algorithms (such as Store and Normal) provided by WinRAR.
- The total length of the decompression path plus the name of any decompressed file cannot exceed 512 characters.
- Currently, encrypted ZIP packages cannot be decompressed.
- Federated users cannot use online decompression. For more information about federated users, see Relationship Between Accounts and Users and Identity Provider Overview.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketCompressPolicy(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| Bucket | string | Yes | Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
| Rules | string | Yes | Explanation: List of online decompression rules. The value is a string in JSON format. Restrictions:
Default value: N/A |
| Type | Description |
| NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
| Parameter | Type | Description |
| CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
| InterfaceResult | Explanation: Results returned for a successful call. For details, see Table 5. Restrictions: This parameter is left blank if the value of Status is greater than 300. |
| Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server. |
| Message | string | Explanation: Error description returned by the OBS server. |
| HostId | string | Explanation: Request server ID returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server. |
| Id2 | string | Explanation: Request ID2 returned by the OBS server. |
| Indicator | string | Explanation: Error code details returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server |
Sample Code
You can call ObsClient.setBucketCompressPolicy to configure an online decompression policy. The sample code is as follows:
// Import the OBS library.
// Use npm for installation.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code for installation.
// var ObsClient = require('./lib/obs');
// Create an ObsClient instance.
// Obtain an AK and SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
access_key_id: process.env.ACCESS_KEY_ID,
secret_access_key: process.env.SECRET_ACCESS_KEY,
// (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
// security_token: process.env.SECURITY_TOKEN,
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function setBucketCompressPolicy() {
try {
// Construct an online decompression rule (JSON string).
const rules = JSON.stringify({
rules: [{
project: 'your_projectId' ,
agency: 'your_agency',
events: ['ObjectCreated:*'],
prefix: 'decompress/',
suffix: '.zip',
overwrite: 0,
decompresspath: 'output/',
policytype: 'decompress'
const params = {
// Specify a bucket name.
Bucket: "examplebucket",
// Specify the online decompression rule.
Rules: rules,
// Configure the online decompression policy.
const result = await obsClient.setBucketCompressPolicy(params);
if (result.CommonMsg.Status <= 300) {
console.log("Set bucket compress policy successful!\n");
console.log("RequestId: %s", result.CommonMsg.RequestId);
return;
console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
console.log("Status: %d", result.CommonMsg.Status);
console.log("Code: %s", result.CommonMsg.Code);
console.log("Message: %s", result.CommonMsg.Message);
} catch (error) {
console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
console.log(error);
setBucketCompressPolicy(); What is your overall rating for this page?
