Deleting the Custom Domain Name of a Bucket (SDK for Node.js)
Function
This API deletes the custom domain name of an OBS bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To delete the custom domain name of a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucketCustomDomain granted using IAM or DeleteBucketCustomDomain granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.deleteBucketCustomDomain(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| Bucket | String | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| DomainName | String | Yes | Explanation: Custom domain name to be deleted Restrictions: None Value range: None Default value: None |
Responses
| Type | Description |
| NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
| Parameter | Type | Description |
| CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
| InterfaceResult | Explanation: Results returned for a successful call. For details, see Table 5. Restrictions: This parameter is left blank if the value of Status is greater than 300. |
| Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server. |
| Message | string | Explanation: Error description returned by the OBS server. |
| HostId | string | Explanation: Request server ID returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server. |
| Id2 | string | Explanation: Request ID2 returned by the OBS server. |
| Indicator | string | Explanation: Error code details returned by the OBS server. |
