Updated on 2026-09-20 GMT+08:00
Checking Whether an Object Exists (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API checks whether an object exists. If the returned HTTP status code is 200, the object exists. If the returned HTTP status code is 404, the object or bucket does not exist.
Restrictions
Method
ObsClient.getObjectMetadata(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Value range:
The value must contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Restrictions:
None
Value range:
The value must contain 32 characters.
Default value:
None
Origin
string
No
Explanation:
Origin of the cross-domain request specified in the preflight request. It is usually a domain name.
Restrictions:
Each origin can contain at most one wildcard character (*).
Value range:
None
Default value:
None
RequestHeader
string
No
Explanation:
HTTP headers that can be used in cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain at most one wildcard character (*). Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
None
Default value:
None
SseC
string
Yes when SSE-C is used
Explanation:
SSE-C is used for decrypting objects.
Restrictions:
Only AES256 is supported.
Value range:
AES256
Default value:
None
SseCKey
string
Explanation:
Key used for decrypting objects when SSE-C is used
Restrictions:
A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=
Value range:
None
Default value:
None
Responses
Table 2 Responses
Type
Table 3
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Type
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results returned for a successful call. For details, see Table 5.
Restrictions:
This parameter is left blank if the value of Status is greater than 300.
Table 4 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 GetObjectMetadataOutput
Type
RequestId
string
Explanation:
StorageClass
StorageClassType
Explanation:
Storage class configured when copying the object. If you do not specify this parameter, the object inherits the storage class of the bucket.
Value range:
See Table 6.
AllowOrigin
string
Explanation:
If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which requests can access the object.
Restrictions:
Domain name of the origin. Each origin can contain at most one wildcard character (*). Example: https://*.vbs.example.com
Default value:
None
AllowHeader
string
Explanation:
If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid.
Restrictions:
Default value:
None
AllowMethod
string
Explanation:
AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method allowed for cross-origin requests, that is, the operation type of buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
ExposeHeader
string
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them in this parameter.
Restrictions:
Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Default value:
None
MaxAgeSeconds
number
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can contain at most one MaxAgeSeconds.
Value range:
0 to (231 – 1), in seconds
Default value:
100
ContentLength
number
Explanation:
Object size
Value range:
0 to (263 – 1), in bytes
Default value:
None
ContentType
string
Explanation:
MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)? (SDK for Node.js).
Default value:
If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter.
LastModified
string
Explanation:
The time when the last modification was made to the object
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An object created by an upload or copy operation has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
VersionId
string
Explanation:
Object version ID
Value range:
Default value:
None
Restore
string
Explanation:
Restoration status of an object. For an Archive object that is being restored or has been restored, this header is returned.
For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored, where expiry-date indicates when the restored object expires.
Restrictions:
If the object is not in the Archive storage class, this parameter is left blank.
Default value:
None
Expiration
string
Explanation:
Expiration details of the object. for example, "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\""
Default value:
None
WebsiteRedirectLocation
string
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
The request is redirected to another object in the bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
Metadata
object
Explanation:
Custom metadata of the object. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB in total. To measure the size, calculate the sum of bytes of all UTF-8 encoded keys and values.
  • The custom metadata keys are case-insensitive, but are stored in lowercase in OBS. The key values are case-sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
Default value:
None
Table 6 StorageClassType
Constant
Default Value
ObsClient.enums.StorageClassStandard
STANDARD
Standard storage class.
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
ObsClient.enums.StorageClassWarm
WARM
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
ObsClient.enums.StorageClassCold
COLD
Archive storage class.
Used for storing rarely accessed (once a year) data.
Sample Code
You can call ObsClient.getObjectMetadata to obtain the metadata of an object, including its length, MIME type, and custom metadata. The following code shows how to obtain the metadata of object example/objectname in bucket examplebucket:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function getObjectMetadata() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify the object (example/objectname in this example).
      Key: 'example/objectname',
    // Obtain the object metadata.
    const result = await obsClient.getObjectMetadata(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Put bucket(%s) successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      console.log("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n",
        result.InterfaceResult.StorageClass, result.InterfaceResult.ETag, result.InterfaceResult.ContentType,
        result.InterfaceResult.ContentLength, result.InterfaceResult.LastModified);
      // Obtain the custom metadata of the object.
      console.log("Metadata:%v", result.InterfaceResult.Metadata);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
getObjectMetadata();
