Copying a Part (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API uploads a part for a specified multipart upload by copying data to a specified bucket.
After initiating a multipart upload task, you can add parts for this task by copying part or all of an existing object in OBS.
Assume that you copy a source object and save it as part1. If there is already an existing part called part1, the new part1 will overwrite the existing part1. Then, only the new part1 can be listed. The old part1 is deleted. To prevent accidental deletion, ensure there is no existing object with the same name as the part involved when using this API. The source object remains unchanged during the copy process.
Restrictions
- To copy a part, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
- You cannot determine whether the operation is successful solely based on status_code returned in the HTTP header. For example, code 200 indicates that the server has received and started to process the request. The copy operation is considered successful only when the response body contains an ETag.
Method
ObsClient.copyPart(params)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
Bucket | string | Yes | Explanation: Destination bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
PartNumber | number | Yes | Explanation: Part number. Restrictions: None Value range: Value range: 1–10000 Default value: None |
UploadId | string | Yes | Explanation: Multipart upload ID, which is generated by initiating a multipart upload. Restrictions: None Value range: The value must contain 32 characters, for example, 000001648453845DBB78F2340DD460D8. Default value: None |
CopySource | string | Yes | Explanation: Names of the source bucket and object. If the source object has multiple versions, the versionId parameter is used to specify the desired version. Example: source_bucket/sourceObject?versionId=G001117FCE89978B0000401205D5DC9A Restrictions: Full-width characters and percent signs (%) must be URL-encoded. Value range: None Default value: None |
Responses
Type | Description |
NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
Parameter | Type | Description |
CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code | string | Explanation: Error code returned by the OBS server. |
Message | string | Explanation: Error description returned by the OBS server. |
HostId | string | Explanation: Request server ID returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server. |
Id2 | string | Explanation: Request ID2 returned by the OBS server. |
Indicator | string | Explanation: Error code details returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server |
ETag | string | Explanation: Base64-encoded, 128-bit MD5 value of an object. The ETag is a unique identifier for the object's contents, used to determine if the object has been updated. For example, if the ETag value is A when an object is uploaded and becomes B when the object is downloaded, this indicates the contents of the object were changed. The ETag reflects changes of an object, not of the metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. |
LastModified | string | Explanation: Time when a part was last modified, in UTC |
PartNumber | number | Explanation: Part number. |
SseKms | string | Explanation: SSE-KMS is used for encrypting objects on the server side. |
SseKmsKey | string | Explanation: ID of the KMS master key when SSE-KMS is used. |
SseC | string | Explanation: SSE-C is used for encrypting objects on the server side. |
SseCKeyMd5 | string | Explanation: MD5 value of the key used for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ== |
Code Examples
This example copies a part from object example/sourceobjectname in bucket sourcebucketname to object example/objectname in bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function copyPart() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify an object. example/objectname is used in this example. Key: "example/objectname", // Specify the names of the source bucket (sourcebucketname in this example) and source object (example/sourceobjectname in this example). CopySource: "sourcebucketname/example/sourceobjectname", // Specify the part number (1 in this example). PartNumber: 1, // Specify the multipart upload ID (00000188677110424014075CC4A77xxx in this example). UploadId: "00000188677110424014075CC4A77xxx", }; // Copy the part. const result = await obsClient.copyPart(params); if (result.CommonMsg.Status <= 300) { console.log("Complete multipart upload successful with bucket(%s) and object(%s)!", params.Bucket, params.Key); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; copyPart(); |
