Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
On this page
Help Center/ Object Storage Service/ SDK Reference/ Node.js/ FAQs (SDK for Node.js)/ What Is Content-Type (MIME)? (SDK for Node.js)
Multipurpose Internet Mail Extensions (MIME) type is a standard way of describing a data type. The MIME type is passed in the Content-Type header.
If you do not specify Content-Type when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to Content-Type.
Content-Type
Content-Type indicates the type of data to send or receive and determine the form and encoding method browsers will use to display data (mainly custom client files or media files). If no content type is specified, the type will be generated based on the file name extension. If there is no extension, the content type is application/octet-stream by default.
Common Content Types
The commonly used content types are given in the table below.
Table 1 List of common content types
File Name Extension
Content-Type(Mime-Type)
File Name Extension
.* (binary stream, unknown file type)
.tif
image/tiff
.a11
application/x-a11
.acp
audio/x-mei-aac
.ai
application/postscript
.aif
audio/aiff
.aifc
audio/aiff
.aiff
audio/aiff
.anv
application/x-anv
.apk
application/vnd.android.package-archive
.asa
text/asa
.asf
video/x-ms-asf
.asp
text/asp
.asx
video/x-ms-asf
.au
audio/basic
.avi
video/avi
.awf
application/vnd.adobe.workflow
.biz
text/xml
.bmp
application/x-bmp
.bot
application/x-bot
.c4t
application/x-c4t
.c90
application/x-c90
.cal
application/x-cals
.cat
application/vnd.ms-pki.seccat
.cdf
application/x-netcdf
.cdr
application/x-cdr
.cel
application/x-cel
.cer
application/x-x509-ca-cert
.cg4
application/x-g4
.cgm
application/x-cgm
.cit
application/x-cit
.class
java/
.cml
text/xml
.cmp
application/x-cmp
.cmx
application/x-cmx
.cot
application/x-cot
.crl
application/pkix-crl
.crt
.csi
application/x-csi
.css
text/css
.csv
text/csv
.cut
application/x-cut
.dbf
application/x-dbf
.dbm
application/x-dbm
.dbx
application/x-dbx
.dcd
text/xml
.dcx
application/x-dcx
.der
.dgn
application/x-dgn
.dib
application/x-dib
.dll
application/x-msdownload
.doc
application/msword
.docx
application/vnd.openxmlformats-officedocument.wordprocessingml.document
.dot
application/msword
.dotx
application/vnd.openxmlformats-officedocument.wordprocessingml.template
.drw
application/x-drw
.dtd
text/xml
.dwf
Model/vnd.dwf
.dwf
application/x-dwf
.dwg
application/x-dwg
.dxb
application/x-dxb
.dxf
application/x-dxf
.edn
application/vnd.adobe.edn
.emf
application/x-emf
.eml
message/rfc822
.ent
text/xml
.epi
application/x-epi
.eps
application/x-ps
.eps
.etd
application/x-ebx
.exe
.fax
image/fax
.fdf
application/vnd.fdf
.fif
application/fractals
.fo
text/xml
.frm
application/x-frm
.g4
application/x-g4
.gbr
application/x-gbr
application/x-
.gif
image/gif
.gl2
application/x-gl2
.gp4
application/x-gp4
.hgl
application/x-hgl
.hmr
application/x-hmr
.hpg
application/x-hpgl
.hpl
application/x-hpl
.hqx
application/mac-binhex40
.hrf
application/x-hrf
.hta
application/hta
.htc
text/x-component
.htm
text/html
.html
text/html
.htt
text/webviewhtml
.htx
text/html
.icb
application/x-icb
.ico
image/x-icon
.ico
application/x-ico
.iff
application/x-iff
.ig4
application/x-g4
.igs
application/x-igs
.iii
application/x-iphone
.img
application/x-img
.ins
application/x-internet-signup
.ipa
application/vnd.iphone
.isp
.IVF
video/x-ivf
.java
java/*
.jfif
image/jpeg
.jpe
image/jpeg
.jpe
application/x-jpe
.jpeg
image/jpeg
.jpg
image/jpeg
.jpg
application/x-jpg
.js
application/x-javascript
.jsp
text/html
.la1
audio/x-liquid-file
.lar
application/x-laplayer-reg
.latex
application/x-latex
.lavs
audio/x-liquid-secure
.lbm
application/x-lbm
.lmsff
audio/x-la-lms
.ls
.ltr
application/x-ltr
.m1v
video/x-mpeg
.m2v
video/x-mpeg
.m3u
audio/mpegurl
.m4e
video/mpeg4
.mac
application/x-mac
.man
application/x-troff-man
.math
text/xml
.mdb
application/msaccess
.mdb
application/x-mdb
.mfp
application/x-shockwave-flash
.mht
message/rfc822
.mhtml
message/rfc822
.mi
application/x-mi
.mid
audio/mid
.midi
audio/mid
.mil
application/x-mil
.mml
text/xml
.mnd
audio/x-musicnet-download
.mns
audio/x-musicnet-stream
.mocha
.mov
video/quicktime
.movie
video/x-sgi-movie
mp1
audio/mp1
.mp2
audio/mp2
.mp2v
video/mpeg
.mp3
audio/mp3
.mp4
video/mp4
.mpa
video/x-mpg
.mpd
application/vnd.ms-project
.mpe
video/x-mpeg
.mpeg
video/mpg
.mpg
video/mpg
.mpga
audio/rn-mpeg
.mpp
.mps
video/x-mpeg
.mpt
.mpv
video/mpg
.mpv2
video/mpeg
.mpw
.mpx
.mtx
text/xml
.mxp
application/x-mmxp
.net
image/pnetvue
.nrf
application/x-nrf
.nws
message/rfc822
.odc
text/x-ms-odc
.out
application/x-out
.p10
application/pkcs10
.p12
application/x-pkcs12
.p7b
application/x-pkcs7-certificates
.p7c
application/pkcs7-mime
.p7m
.p7r
application/x-pkcs7-certreqresp
.p7s
application/pkcs7-signature
.pc5
application/x-pc5
.pci
application/x-pci
.pcl
application/x-pcl
.pcx
application/x-pcx
.pdf
application/pdf
.pdb
chemical/x-pdb
.pdx
application/vnd.adobe.pdx
.pfx
.pgl
application/x-pgl
.pic
application/x-pic
.pko
application/vnd.ms-pki.pko
.pl
application/x-perl
.plg
text/html
.pls
audio/scpls
.plt
application/x-plt
.png
image/png
.png
application/x-png
.pot
application/vnd.ms-powerpoint
.potx
application/vnd.openxmlformats-officedocument.presentationml.template
.ppa
.ppm
application/x-ppm
.pps
.ppsx
application/vnd.openxmlformats-officedocument.presentationml.slideshow
.ppt
.ppt
application/x-ppt
. pptx
application/vnd.openxmlformats-officedocument.presentationml.presentation
.pr
application/x-pr
.prf
application/pics-rules
.prn
application/x-prn
.prt
application/x-prt
.ps
application/x-ps
.ps
.ptn
application/x-ptn
.pwz
.r3t
text/vnd.rn-realtext3d
.ra
audio/vnd.rn-realaudio
.ram
audio/x-pn-realaudio
.ras
application/x-ras
.rat
application/rat-file
.rdf
text/xml
.rec
application/vnd.rn-recording
.red
application/x-red
.rgb
application/x-rgb
.rjs
application/vnd.rn-realsystem-rjs
.rjt
application/vnd.rn-realsystem-rjt
.rlc
application/x-rlc
.rle
application/x-rle
.rm
application/vnd.rn-realmedia
.rmf
application/vnd.adobe.rmf
.rmi
audio/mid
.rmj
application/vnd.rn-realsystem-rmj
.rmm
.rmp
application/vnd.rn-rn_music_package
.rms
application/vnd.rn-realmedia-secure
.rmvb
application/vnd.rn-realmedia-vbr
.rmx
application/vnd.rn-realsystem-rmx
.rnx
application/vnd.rn-realplayer
.rp
image/vnd.rn-realpix
.rpm
audio/x-pn-realaudio-plugin
.rsml
application/vnd.rn-rsml
.rt
.rtf
application/msword
.rtf
application/x-rtf
.rv
video/vnd.rn-realvideo
.sam
application/x-sam
.sat
application/x-sat
.sdp
application/sdp
.sdw
application/x-sdw
.sis
application/vnd.symbian.install
.sisx
.sit
application/x-stuffit
.slb
application/x-slb
.sld
application/x-sld
.sldx
.slk
drawing/x-slk
.smi
application/smil
.smil
application/smil
.smk
application/x-smk
.snd
audio/basic
.sol
text/plain
.sor
text/plain
.spc
.spl
application/futuresplash
.spp
text/xml
.ssm
application/streamingmedia
.sst
application/vnd.ms-pki.certstore
.stl
application/vnd.ms-pki.stl
.stm
text/html
.sty
application/x-sty
.svg
image/svg+xml
.swf
.tdf
application/x-tdf
.tg4
application/x-tg4
.tga
application/x-tga
.tif
image/tiff
.tif
application/x-tif
.tiff
image/tiff
.tld
text/xml
.top
drawing/x-top
.torrent
application/x-bittorrent
.tsd
text/xml
.txt
text/plain
.uin
application/x-icq
.uls
text/iuls
.vcf
text/x-vcard
.vda
application/x-vda
.vdx
application/vnd.visio
.vml
text/xml
.vpg
application/x-vpeg005
.vsd
.vsd
application/x-vsd
.vss
.vst
.vst
application/x-vst
.vsw
.vsx
.vtx
.vxml
text/xml
.wav
audio/wav
.wax
audio/x-ms-wax
.wb1
application/x-wb1
.wb2
application/x-wb2
.wb3
application/x-wb3
.wbmp
image/vnd.wap.wbmp
.wiz
application/msword
.wk3
application/x-wk3
.wk4
application/x-wk4
.wkq
application/x-wkq
.wks
application/x-wks
.wm
video/x-ms-wm
.wma
audio/x-ms-wma
.wmd
application/x-ms-wmd
.wmf
application/x-wmf
.wml
text/vnd.wap.wml
.wmv
video/x-ms-wmv
.wmx
video/x-ms-wmx
.wmz
application/x-ms-wmz
.wp6
application/x-wp6
.wpd
application/x-wpd
.wpg
application/x-wpg
.wpl
application/vnd.ms-wpl
.wq1
application/x-wq1
.wr1
application/x-wr1
.wri
application/x-wri
.wrk
application/x-wrk
.ws
application/x-ws
.ws2
application/x-ws
.wsc
text/scriptlet
.wsdl
text/xml
.wvx
video/x-ms-wvx
.xap
application/x-silverlight-app
.x_b
application/x-x_b
.xdp
application/vnd.adobe.xdp
.xdr
text/xml
.xfd
application/vnd.adobe.xfd
.xfdf
application/vnd.adobe.xfdf
.xhtml
text/html
.xls
application/vnd.ms-excel
.xls
application/x-xls
.xlsx
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
.xltx
application/vnd.openxmlformats-officedocument.spreadsheetml.template
.xlw
application/x-xlw
.xml
text/xml
.xpl
audio/scpls
.xq
text/xml
.xql
text/xml
.xquery
text/xml
.xsd
text/xml
.xsl
text/xml
.xslt
text/xml
.xwd
application/x-xwd
.x_t
application/x-x_t
.yaml
text/vnd.yaml
.yml
text/vnd.yml
.webp
image/webp
.tar
application/x-tar
.zip
application/zip
