APIs (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
The following table lists APIs related to server-side encryption:
Method in OBS Node.js SDK | Description | Supported Encryption Type |
ObsClient.putObject | Sets the encryption algorithm and key during object upload to enable server-side encryption. | SSE-KMS SSE-C |
ObsClient.appendObject | Sets the encryption algorithm and key during appendable upload to enable server-side encryption. | SSE-KMS SSE-C |
ObsClient.getObject | Sets the decryption algorithm and key during object download to decrypt the object. | SSE-C |
ObsClient.copyObject |
| SSE-KMS SSE-C |
ObsClient.getObjectMetadata | Sets the decryption algorithm and key when obtaining the object metadata to decrypt the object. | SSE-C |
ObsClient.initiateMultipartUpload | Sets the encryption algorithm and key when initializing a multipart upload to enable server-side encryption for the final object generated. | SSE-KMS SSE-C |
ObsClient.uploadPart | Sets the encryption algorithm and key during multipart upload to enable server-side encryption for parts. | SSE-C |
ObsClient.copyPart |
| SSE-C |
OBS Node.js SDK supports the following two types of encryption/decryption mode:
Encryption/Decryption Type | Request Parameter | Description |
SSE-KMS | SseKms | Indicates that SSE-KMS mode is used. Currently, only kms is supported. |
SseKmsKey | Indicates the master key used in SSE-KMS mode. The value can be null. | |
SSE-C | SseC | Indicates that SSE-C mode is used. Currently, only AES256 is supported. |
SseCKey | Indicates the key in SSE-C mode. It is calculated using the AES256 algorithm. This parameter can be used to encrypt an object to be uploaded and decrypt an object to be downloaded. | |
CopySourceSseC | Indicates the source object decrypted in SSE-C mode. The value can only be AES256. This parameter is applicable to ObsClient.copyObject and ObsClient.copyPart. | |
CopySourceSseCKey | Indicates the key used by a source object for decryption in SSE-C mode. It is calculated using the AES256 algorithm. This parameter is applicable to ObsClient.copyObject and ObsClient.copyPart. |
