Setting Bucket Tags (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
If you add tags to a bucket, SDRs generated for the requests sent to this bucket will include these tags, so you can use the tags to classify SDRs for detailed cost analysis. For example, if you have an application that uploads its data to a bucket when it is running, you can tag the bucket with the name of this application. Then, you can analyze the cost of this application by using that tag.
This API adds tags to a bucket.
For more information about bucket tags, see Tags.
Restrictions
- A bucket can have a maximum of 10 tags.
- A tag key and its value can contain a maximum of 128 and 255 characters, respectively.
- Tag keys and values cannot contain commas (,), asterisks (*), vertical bars (|), slashes (/), less-than signs (<), greater-than signs (>), equal signs (=), backslashes (\), or ASCII codes (0x00 to 0x1F).
- To add tags to a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketTagging in IAM or PutBucketTagging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.setBucketTagging(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| Bucket | string | Yes | Bucket name Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
| Tags | Tag[] | Yes | Explanation: Bucket tag set. Restrictions:
Value range: See Tag. Default value: None |
Responses
| Type | Description |
| NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 4. |
| Parameter | Type | Description |
| CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5. | |
| InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 6. Restrictions: This parameter is not included if the value of Status is greater than 300. |
| Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server. |
| Message | string | Explanation: Error description returned by the OBS server. |
| HostId | string | Explanation: Request server ID returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server. |
| Id2 | string | Explanation: Request ID2 returned by the OBS server. |
| Indicator | string | Explanation: Error code details returned by the OBS server. |
Code Examples
The following code shows how to set tags for the examplebucket bucket:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function setBucketTagging() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify bucket tags. Tags: [ {Key: "key0", Value: "value0"}, {Key: "key1", Value: "value1"}, ] }; // Set bucket tags. const result = await obsClient.setBucketTagging(params); if (result.CommonMsg.Status <= 300) { console.log("Set bucket(%s)'s tagging configuration successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; setBucketTagging(); |
