Disabling Bucket Logging
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.setBucketLogging to clear logging settings of a bucket so as to disable logging of the bucket. Sample code is as follows:
// Import the OBS library. // Use npm to install the client. var ObsClient = require('esdk-obs-nodejs'); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an ObsClient instance. const obsClient = new ObsClient({ //Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, //CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.setBucketLogging({ Bucket:'bucketname', LoggingEnabled : {} }, (err, result) => { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
