Setting an ACL for an Object Version (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API calls ObsClient.setObjectAcl to set an ACL for an object version specified by the VersionId parameter. For details about the API definition, see Configuring an Object ACL (SDK for Node.js).
Code Examples
This example sets the ACL to allow all users to read object example/objectname from bucket examplebucket but only allow user 0a03f5833900d3730f13c00f49d5exxx to write.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function setObjectAcl() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify an object. example/objectname is used in this example. Key: "example/objectname", // Specify the version ID of the object. VersionId: 'G001117FCE89978B0000401205D5DC9A', // Specify the owner of the object. Owner: { 'ID': 'ownerid' }, // Specify the information about the authorized user. Grants: [ // Grant the write permission to a specified user (0a03f5833900d3730f13c00f49d5exxx in this example). { Grantee: { Type: 'CanonicalUser', ID: '0a03f5833900d3730f13c00f49d5exxx' }, Permission: obsClient.enums.PermissionWrite }, // Grant the read permission to all users. { Grantee: { Type: 'Group', URI: obsClient.enums.GroupAllUsers }, Permission: obsClient.enums.PermissionRead }, ] }; // Set the ACL. const result = await obsClient.setObjectAcl(params); if (result.CommonMsg.Status <= 300) { console.log("Set Object(%s)'s acl successful with Bucket(%s)!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; setObjectAcl(); |
- For details about the error codes returned during the configuration of permissions for versioned objects, see OBS Server-Side Error Codes (SDK for Node.js).
