Updated on 2026-07-22 GMT+08:00
Obtaining the ACL of an Object (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
For more information, see ACLs.
This API returns the ACL of an object.
Restrictions
Method
ObsClient.getObjectAcl(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Restrictions:
None
Value range:
The value must contain 32 characters.
Default value:
None
Responses
Table 2 Responses
Type
Table 3
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Type
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 GetObjectAclOutput
Type
RequestId
string
Explanation:
VersionId
string
Explanation:
Owner
Owner
Explanation:
Object owner. For details, see Owner.
Delivered
string
Explanation:
Whether the bucket ACL is applied to the objects in the bucket.
Grants
Grant[]
Explanation:
Grantees' permission information. For details, see Table 7.
Table 6 Owner
Type
Mandatory (Yes/No)
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK).
Default value:
None
DisplayName
string
No
Explanation:
Account name of the owner
Default value:
None
Table 7 Grant
Type
Mandatory (Yes/No)
Grantee
Grantee
Explanation:
Grantee information. For details, see Table 8.
Permission
PermissionType
Explanation:
Granted permission
Value range:
See Table 11.
Table 8 Grantee
Type
Mandatory (Yes/No)
Type
string
Explanation:
Grantee type
Value range:
See Table 9.
Default value:
None
ID
string
Yes if this parameter is used as a request parameter and Type is set to a user
Explanation:
Account (domain) ID of the grantee.
Value range:
Default value:
None
Name
string
No if used as a request parameter
Explanation:
Account name of the grantee.
Restrictions:
  • The account name cannot contain full-width characters.
  • The account name starts with a letter.
  • The account name contains 6 to 32 characters.
  • The account name contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Yes if this parameter is used as a request parameter and Type is set to a group
Explanation:
Authorized user group
Value range:
See Table 10.
Default value:
None
Table 9 GranteeType
Constant
Group
Grants permissions to user groups.
CanonicalUser
Grants permissions to individual users.
Table 10 GroupUriType
Constant
Default Value
ObsClient.enums.GroupAllUsers
AllUsers
All users.
ObsClient.enums.GroupAuthenticatedUsers
AuthenticatedUsers
Authorized users. This constant is deprecated.
ObsClient.enums.GroupLogDelivery
LogDelivery
Log delivery group. This constant is deprecated.
Table 11 PermissionType
Constant
Default Value
ObsClient.enums.PermissionRead
READ
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
ObsClient.enums.PermissionWrite
WRITE
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not applicable to objects.
ObsClient.enums.PermissionReadAcp
READ_ACP
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
ObsClient.enums.PermissionWriteAcp
WRITE_ACP
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
ObsClient.enums.PermissionFullControl
FULL_CONTROL
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket.
A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object.
Code Examples
This example returns the ACL of object example/objectname.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function getObjectAcl() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify the object (example/objectname in this example).
      Key: 'example/objectname',
    // Obtain the object ACL.
    const result = await obsClient.getObjectAcl(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Get object(%s)'s acl successful with bucket(%s)!", params.Key, params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      console.log('Owner[ID]: %s', result.InterfaceResult.Owner.ID);
      console.log('Owner[Name]: %s', result.InterfaceResult.Owner.Name);
      for (let i = 0; i < result.InterfaceResult.Grants.length; i++) {
        const grant = result.InterfaceResult.Grants[i];
        fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n",
          index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission)
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
getObjectAcl();
