Downloading an Object - File-Based (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API downloads an object as a file from OBS to your local computer.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
- Objects in the Archive storage class can be downloaded only when they are in the Restored status.
Method
ObsClient.getObject(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| Bucket | string | Yes | Explanation: Bucket name Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
| Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
| VersionId | string | No | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A Restrictions: None Value range: The value must contain 32 characters. Default value: None |
| SaveAsFile | string | No | Explanation: The download path with the file name contained Restrictions: A file name must be included in the path, for example, aa/bb.txt. Value range: None Default value: None |
| SaveAsStream | boolean | No | Explanation: Whether the object is returned as a readable stream Value range:
Default value: false |
| ProgressCallback | function | No | Explanation: Callback function for obtaining the download progress NOTE: This callback function contains the following parameters in sequence: number of downloaded bytes, total bytes, and used time (unit: second). Restrictions: None Value range: None Default value: None |
| IfMatch | string | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. Restrictions: None Value range: The value must contain 32 characters. Default value: None |
| IfModifiedSince | string | No | Explanation: If the object was modified after the time specified by this parameter, its content is returned. Otherwise, an error code is returned. Restrictions: The value must conform with the HTTP time format specified in http://www.ietf.org/rfc/rfc2616.txt. Value range: None Default value: None |
| IfNoneMatch | string | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Restrictions: None Value range: The value must contain 32 characters. Default value: None |
| IfUnmodifiedSince | string | No | Explanation: If the object was modified before the time specified by this parameter, its content is returned. Otherwise, an error code is returned. Restrictions: The value must conform with the HTTP time format specified in http://www.ietf.org/rfc/rfc2616.txt. Value range: None Default value: None |
| Range | string | No | Explanation: Download range. For example, 0-999 indicates the range is from byte 1 to byte 1000. Restrictions: The maximum length of Range is the length of the object minus 1. If the specified value exceeds this limit, the length of the object minus 1 is used. Value range: 0 to the object length minus 1. Format: bytes=x-y Default value: None |
| Origin | string | No | Explanation: Origin of the cross-domain request specified in the preflight request. It is usually a domain name. Restrictions: Each origin can contain at most one wildcard character (*). Value range: None Default value: None |
| RequestHeader | string | No | Explanation: HTTP headers that can be used in cross-origin requests. Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Value range: None Default value: None |
| ResponseCacheControl | string | No | Explanation: This parameter is used to rewrite the Cache-Control header in the response. Restrictions: None Value range: See the Cache-Control values defined in HTTP. Default value: None |
| ResponseContentDisposition | string | No | Explanation: This parameter is used to rewrite the Content-Disposition header in the response. Restrictions: None Value range: See the Content-Disposition values defined in HTTP. Default value: None |
| ResponseContentEncoding | string | No | Explanation: This parameter is used to rewrite the Content-Encoding header in the response. Restrictions: None Value range: See the Content-Encoding values defined in HTTP. Default value: None |
| ResponseContentLanguage | string | No | Explanation: This parameter is used to rewrite the Content-Language header in the response. Restrictions: None Value range: See the Content-Language values defined in HTTP. Default value: None |
| ResponseContentType | string | No | Explanation: This parameter is used to rewrite the Content-Type header in the response. Restrictions: None Value range: See What Is Content-Type (MIME)? (SDK for Node.js) Default value: None |
| ResponseExpires | string | No | Explanation: This parameter is used to rewrite the Expires header in the response. Restrictions: None Value range: See the Expires values defined in HTTP. Default value: None |
| ImageProcess | string | No | Explanation: Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90 Restrictions: None Value range: Command format: image/commands Style format: style/style-name For details about image processing parameters, see Processing Images. Default value: If no commands are entered, the original image is returned. |
| SseC | string | Yes when SSE-C is used | Explanation: SSE-C is used for decrypting objects. Restrictions: Only AES256 is supported. Value range: AES256 Default value: None |
| SseCKey | string | Yes when SSE-C is used | Explanation: Key used for decrypting objects when SSE-C is used Restrictions: A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw= Value range: None Default value: None |
- If a download request includes IfUnmodifiedSince or IfMatch but does not meet the conditions specified by these parameters, an exception is thrown with HTTP status code 412 Precondition Failed.
- If a download request includes IfModifiedSince or IfNoneMatch but does not meet the conditions specified by these parameters, an exception is thrown with HTTP status code 304 Not Modified.
Responses
| Type | Description |
| NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
| Parameter | Type | Description |
| CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
| InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
| Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server. |
| Message | string | Explanation: Error description returned by the OBS server. |
| HostId | string | Explanation: Request server ID returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server. |
| Id2 | string | Explanation: Request ID2 returned by the OBS server. |
| Indicator | string | Explanation: Error code details returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server |
| DeleteMarker | string | Explanation: Whether the deleted object is a delete marker. |
| LastModified | string | Explanation: Time when the object was last modified. |
| ContentLength | string | Explanation: Object size |
| CacheControl | string | Explanation: Cache-Control header in the response. |
| ContentDisposition | string | Explanation: Content-Disposition header in the response |
| ContentEncoding | string | Explanation: Content-Encoding header in the response |
| ContentLanguage | string | Explanation: Content-Language header in the response |
| ContentType | string | Explanation: MIME type of the object |
| Expires | string | Explanation: Expires header in the response |
| ETag | string | Explanation: ETag of the object. |
| VersionId | string | Explanation: Object version ID |
| WebsiteRedirectLocation | string | Explanation: Location where an object is redirected. It is available when website hosting is configured for a bucket. |
| StorageClass | string | Explanation: Object storage class. If the storage class is Standard, this parameter is left blank. |
| Restore | string | Explanation: Restoration status of the object in the Archive storage class |
| Expiration | string | Explanation: Expiration details |
| Content | string | stream.Readable | Explanation: Content of the object. The content is left blank if SaveAsFile was specified. The content is a stream.Readable object if SaveAsStream was set to true. The content is a Buffer object if neither SaveAsFile nor SaveAsStream was specified. |
| Metadata | object | Explanation: Custom metadata of the object. You need to add in the CORS configurations the additional headers allowed to be carried in the response. For example, you can add the x-amz-meta-property1 header to allow custom metadata property1 to be returned. |
Code Examples
This example downloads object examplebucket/objectname as a file.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getObject() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object to download (example/objectname in this example). Key: 'example/objectname', // Specify the destination path for the downloaded object. SaveAsFile: 'localfile' }; // Download an object as a file. const result = await obsClient.getObject(params); if (result.CommonMsg.Status <= 300) { console.log("Get object(%s) under the bucket(%s) successful!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getObject(); |
