Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Bucket APIs (SDK for Node.js)/ Block Public Access (BPA) (SDK for Node.js)/ Obtaining the Public Access Status of a Bucket Policy (SDK for Node.js)
Updated on 2026-09-20 GMT+08:00
Function
This API obtains the public access status of an OBS bucket policy.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
ObsClient.getBucketPolicyPublicStatus(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Type
Table 3
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Type
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 Parameters of the returned results
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
IsPublic
Boolean
Explanation:
Whether the bucket is public.
Default value:
False
