Configuring BPA for a Bucket (SDK for Node.js)
Function
This API creates or modifies the public access block configuration of an OBS bucket by enabling or disabling the feature.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To configure BPA for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketPublicAccessBlock in IAM or PutBucketPublicAccessBlock in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- If public access block is enabled, existing public access permissions are ignored and new public access permissions cannot be configured. If public access block is disabled, existing public access permissions continue to apply and new public access permissions can be configured.
- By default, BPA is disabled for new POSIX buckets but is enabled for new object buckets.
Method
ObsClient.putBucketPublicAccessBlock(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| blockPublicAcls | bool | No | Explanation: Whether to block public ACLs. If this parameter is set to True, objects cannot be uploaded when the request includes a public ACL. Requests for modifying bucket or object ACLs fail if the requests include public ACLs. Restrictions: None Value range:
| ignorePublicAcls | bool | No | Explanation: Whether to ignore public ACLs. If this parameter is set to True, the public ACL does not take effect during OpenAPI permissions checks. Restrictions: None Value range:
| blockPublicPolicy | bool | No | Explanation: Whether to block the public policy. If this parameter is set to True, OBS rejects calls to modify bucket policies if the specified bucket policy allows public access. Restrictions: None Value range:
| restrictPublicBuckets | bool | No | Explanation: Whether to restrict account access. If this parameter is set to True, only cloud service accounts and this account can access the bucket if a public bucket policy is found during the OpenAPI permissions check. Restrictions: None Value range:
Responses
| Type | Description |
| NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
| Parameter | Type | Description |
| CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
| InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
| Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server. |
| Message | string | Explanation: Error description returned by the OBS server. |
| HostId | string | Explanation: Request server ID returned by the OBS server. |
| RequestId | string | Explanation: Request ID returned by the OBS server. |
| Id2 | string | Explanation: Request ID2 returned by the OBS server. |
| Indicator | string | Explanation: Error code details returned by the OBS server. |
