Obtaining Bucket Metadata (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API returns information about a bucket, including the storage class, region, CORS rules, and redundancy policy.
Restrictions
- To obtain bucket metadata, you must be the bucket owner or have the required permission (obs:bucket:HeadBucket in IAM or HeadBucket in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.getBucketMetadata(params)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
Bucket | string | Yes | Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Responses
Type | Description |
NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 3. |
Parameter | Type | Description |
CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4. | |
InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 5. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code | string | Explanation: Error code returned by the OBS server. |
Message | string | Explanation: Error description returned by the OBS server. |
HostId | string | Explanation: Request server ID returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server. |
Id2 | string | Explanation: Request ID2 returned by the OBS server. |
Indicator | string | Explanation: Error code details returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
StorageClass | Explanation: Storage class of the bucket. Value range: See Table 6. Default value: If the storage class of the bucket is Standard, this parameter is not specified. | |
Location | string | Explanation: Region where a bucket is located. Restrictions: If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
ObsVersion | string | Explanation: OBS version of the bucket. Value range:
AllowOrigin | string | Explanation: If Origin in the request meets the CORS rules of the bucket, AllowedOrigin specified in the CORS rules is returned. AllowedOrigin indicates the origin from which requests can access the bucket. Restrictions: Domain name of the origin. Each origin can contain at most one wildcard character (*). Example: https://*.vbs.example.com Default value: None |
AllowHeader | string | Explanation: If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader specified in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain at most one wildcard character (*). Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Default value: None |
AllowMethod | string | Explanation: AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method allowed for cross-origin requests, that is, the operation type of buckets and objects. Value range: The following HTTP methods are supported:
ExposeHeader | string | Explanation: ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers. Restrictions: Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Default value: None |
MaxAgeSeconds | number | Explanation: MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request. Restrictions: Each CORS rule can contain at most one MaxAgeSeconds. Value range: 0 to (231 – 1), in seconds Default value: 100 |
MultiEnterprise | string | Explanation: Enterprise project ID that can be specified during bucket creation. If you have enabled EPS, you can obtain the project ID from the EPS console. Restrictions: The value of epid is a UUID. epid is not required if you have not enabled EPS yet. Example: 9892d768-2d13-450f-aac7-ed0e44c2585f Value range: To obtain the enterprise project ID, see How Do I Obtain an Enterprise Project ID? Default value: None |
AzRedundancy | string | No Explanation: Data redundancy type that can be specified at bucket creation. Restrictions: Multi-AZ redundancy is not available for Archive storage. If the region where the bucket is located does not support multi-AZ storage, the bucket adopts single-AZ storage by default. Value range: To configure multi-AZ storage for the bucket, set this parameter to 3az. To configure single-AZ storage (default value assigned by OBS) for the bucket, you do not need to specify this parameter. Default value: single AZ |
Constant | Default Value | Description |
ObsClient.enums.StorageClassStandard | STANDARD | Standard storage class. Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
ObsClient.enums.StorageClassWarm | WARM | Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed. |
ObsClient.enums.StorageClassCold | COLD | Archive storage class. Used for storing rarely accessed (once a year) data. |
Code Examples
You can call ObsClient.getBucketMetadata to obtain the metadata of a bucket. This example uses bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getBucketMetadata() { try { const params = { // Specify the bucket name. Bucket: "examplebucket" }; // Obtain the bucket metadata. const result = await obsClient.getBucketMetadata(params); if (result.CommonMsg.Status <= 300) { console.log("Delete bucket(%s)'s metadata successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log('StorageClass: %s', result.InterfaceResult.StorageClass); console.log('Location: %s', result.InterfaceResult.Location); console.log('AZRedundancy: %s', result.InterfaceResult.AZRedundancy); console.log('Epid: %s', result.InterfaceResult.Epid); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; getBucketMetadata(); |
