Updated on 2026-09-20 GMT+08:00
Listing Buckets (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
OBS buckets are containers for storing objects you upload to OBS. This API returns a list of all buckets that meet the specified conditions in all regions of the current account. Returned buckets are listed in alphabetical order by bucket name.
Restrictions
  • To list buckets, you must have the obs:bucket:ListAllMyBuckets permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
Method
ObsClient.listBuckets(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
QueryLocation
boolean
No
Explanation:
Whether to query the bucket location
Restrictions:
None
Value range:
  • true: The bucket location is queried.
  • false: The bucket location is not queried.
Default value:
false
BucketType
string
No
Explanation:
Type of bucket.
Restrictions:
None
Value range:
See BucketType.
Default value:
None. If this parameter is not specified, all buckets and parallel file systems are listed.
Table 2 BucketType
Constant
OBJECT
An object bucket
POSIX
A parallel file system (POSIX)
Responses
Table 3 Responses
Type
Table 4
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 4.
Table 4 Response
Type
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5.
InterfaceResult
ListBucketsOutput
Explanation:
Results outputted for a successful call. For details, see Table 6.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 5 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 6 ListBucketsOutput
Type
RequestId
string
Explanation:
Default value:
None
Owner
Owner
Explanation:
Bucket owner
Value range:
See Table 7.
Buckets
Bucket[]
Explanation:
Bucket information list
Value range:
See Table 8.
Table 7 Owner
Type
Mandatory (Yes/No)
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK).
Default value:
None
DisplayName
string
No
Explanation:
Account name of the owner
Default value:
None
Table 8 Bucket
Type
BucketName
string
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
Default value:
None
CreationDate
string
Explanation:
When the bucket was created.
Default value:
None
Location
string
Explanation:
Where a bucket is located.
Restrictions:
If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required.
Value range:
To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator.
Default value:
If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default.
BucketType
string
Explanation:
Bucket type
Value range:
  • Object bucket: OBJECT
  • Parallel file system: POSIX
Default value:
None
Code Examples
You can call ObsClient.listBuckets to list buckets. This example lists all buckets.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function listBuckets() {
  try {
    const params = {
      // Specify whether to query the bucket location in the listing. The default value is false. true is used in this example.
      QueryLocation: true,
      // Specify a bucket type (object buckets in this example). If this parameter is not specified, object buckets and parallel file systems are listed by default.
      BucketType: "OBJECT",
    // List buckets.
    const result = await obsClient.listBuckets(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("List buckets successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      console.log('Owner:');
      console.log('ID: %s', result.InterfaceResult.Owner.ID);
      console.log('Name: %s', result.InterfaceResult.Owner.Name);
      console.log('Buckets:');
      for (let i = 0; i < result.InterfaceResult.Buckets.length; i++) {
          const val = result.InterfaceResult.Buckets[i];
          console.log("Bucket[%d]-Name:%s,CreationDate:%s,Location: %s",
            i, val.BucketName, val.CreationDate, val.Location);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
listBuckets();
