Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Initialization (SDK for Node.js)/ Configuring an SDK Proxy (SDK for Node.js)
Updated on 2024-11-13 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
- In the root directory of the project, run the following command to download the proxy-agent dependency.
npm install --save proxy-agent
- Declare and configure proxies in the project.
const ProxyAgent = require("proxy-agent"); const proxyAgent = new ProxyAgent(`http://username:password@proxyhost:proxyPort`); - Initialize an ObsClient instance and configure a proxy.
var obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" https_agent:proxyAgent, http_agent: proxyAgent, });
Parent topic: Initialization (SDK for Node.js)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
