Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
On this page
Show all
Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Initialization (SDK for Node.js)/ Configuring an Instance of ObsClient (SDK for Node.js)
Updated on 2025-05-20 GMT+08:00
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub.
You can set the following initialization parameters to configure an instance of ObsClient.
Recommended Value
access_key_id
AK
N/A
secret_access_key
SK
N/A
server
Endpoint for accessing OBS, which contains the protocol type, domain name (or IP address), and port number. For example, https://your-endpoint:443. For security purposes, you are advised to use HTTPS.
N/A
max_retry_count
Maximum number of retries when an HTTP/HTTPS connection is abnormal. The default value is 3.
[1, 5]
timeout
Timeout period (in seconds) of an HTTP/HTTPS request. The default value is 60.
[10, 60]
http_agent
(Optional) Whether to use the HTTP agent. By default, this parameter is not configured.
N/A
https_agent
(Optional) Whether to use the HTTPS agent. By default, this parameter is not configured.
N/A
ssl_verify
Whether to verify server-side certificates. Possible values are:
  • Path to the server-side root certificate file in .pem format
  • true: The default CAs are used to verify the server-side certificate.
  • false: The server-side certificates will not be verified.
The default value is false.
N/A
long_conn_param
Persistent connection mode (in seconds). If the value is equal to or larger than 0, the persistent connection mode is enabled and this value is used as the initial delay of the TCP Keep-Alive packets.
By default, this parameter is left blank, which indicates that persistent connection mode is disabled.
N/A
is_cname
Whether to use self-defined domain name to access OBS. The default value is false.
N/A
  • Parameters whose recommended value is N/A need to be set according to the actual conditions.
  • If the network is unstable, you are advised to set a larger value for timeout.
  • If the value of server does not contain any protocol, HTTPS is used by default.
NOTICE:
  • If the persistent connection mode is enabled, you must call ObsClient.close to close ObsClient explicitly to reclaim connection resources.
  • For the sake of high DNS resolution performance and OBS reliability, you can set server only to the domain name of OBS, instead of the IP address.
  • For details about SDK proxy configuration, see Configuring an SDK Proxy (SDK for Node.js).
