Help Center/Object Storage Service/SDK Reference/Node.js/Example Programs (SDK for Node.js)
Updated on 2024-11-13 GMT+08:00
OBS Node.js SDK provides abundant example programs for user reference and direct use. These programs can be obtained from the OBS Node.js SDK development package. For example, files in eSDK_Storage_OBS_<VersionId>_Node.js/examples obtained by decompressing eSDK_Storage_OBS_<VersionId>_Node.js.zip are example programs. Alternatively, you can click code package names provided in the following table to obtain corresponding example programs.
Example programs include:
Code Example
bucket-operations-sample
How to use bucket-related APIs.
object-operations-sample
How to use object-related APIs.
download-sample
How to download an object.
create-folder-sample
How to create a folder.
delete-objects-sample
How to delete objects in a batch.
list-objects-sample
How to list objects.
list-versions-sample
How to list versioning objects.
list-objects-infolder-sample
How to list objects in a folder.
object-meta-sample
How to customize object metadata.
simple-multipart-upload-sample
How to perform a multipart upload.
restore-object-sample
How to download Archive objects.
concurrent-copypart-sample
How to concurrently copy parts of a large object.
concurrent-download-object-sample
How to concurrently download parts of a large object.
concurrent-uploadpart-sample
How to concurrently upload parts of a large object.
post-object-sample
How to perform a browser-based upload.
temporary-signature-sample
How to use URLs for authorized access.
