Updated on 2026-09-10 GMT+08:00
Deleting the Custom Domain Name of a Bucket (SDK for Java)
Function
This API is used to delete the custom domain names of an OBS bucket.
Restrictions
Method
ObsClient.deleteBucketCustomDomain(DeleteBucketCustomDomainRequest request)
Request Parameters
Table 1 DeleteBucketCustomDomainRequest
Type
Mandatory (Yes/No)
bucketName
str
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Value range:
None
Default value:
None
domainName
String
Yes
Explanation:
Custom domain name.
Restrictions:
None
Value range:
None
Default value:
None
Responses
Table 2 Common response headers
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Sample Code
This example deletes the custom domain name of a bucket.
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.DeleteBucketCustomDomainRequest;
import com.obs.services.model.HeaderResponse;
import java.util.Map;
public class DeleteBucketCustomDomain {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use.
        // Obtain an endpoint using environment variables or import it in other ways.
        // String endPoint = System.getenv("ENDPOINT");
        String endPoint = "https://obs.cn-north-4.myhuaweicloud.com";
        // Create an ObsClient instance.
        try (ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint)) {
            // Example bucket name
            String exampleBucket = "example-bucket";
            // Example custom domain name
            String exampleDomainName = "example.domain.name.com";
            DeleteBucketCustomDomainRequest deleteBucketCustomDomainRequest =
                new DeleteBucketCustomDomainRequest(exampleBucket,exampleDomainName);
            // Delete the custom domain name of the bucket.
            HeaderResponse response =
                obsClient.deleteBucketCustomDomain(deleteBucketCustomDomainRequest);
            System.out.println("StatusCode:" + response.getStatusCode());
            System.out.println("RequestId:" + response.getRequestId());
            System.out.println("DeleteBucketCustomDomain successfully");
        } catch (ObsException e) {
            System.out.println("DeleteBucketCustomDomain failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            // Check all Map entries and print all headers associated with the error.
            Map<String, String> headers = e.getResponseHeaders();
            if(headers != null){
                for (Map.Entry<String, String> header : headers.entrySet()) {
                    System.out.println(header.getKey()+":"+header.getValue());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
