Obtaining the Custom Domain Names of a Bucket (SDK for Java)
Function
This API obtains the custom domain names of a bucket.
Restrictions
- To obtain the custom domain names of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketCustomDomain granted using IAM or GetBucketCustomDomain granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.getBucketCustomDomain(GetBucketCustomDomainRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Value range: None Default value: None |
Responses
| Type | Description |
| Explanation: Information about the custom domain names of a bucket. |
| Parameter | Type | Description |
| domains | List<Domains> | Explanation: Custom domain name list. |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.BucketCustomDomainInfo;
import com.obs.services.model.GetBucketCustomDomainRequest;
import java.util.Map;
public class GetBucketCustomDomain {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use.
// Obtain an endpoint using environment variables or import it in other ways.
// String endPoint = System.getenv("ENDPOINT");
String endPoint = "https://obs.cn-north-4.myhuaweicloud.com";
// Create an ObsClient instance.
try (ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint)) {
// Example bucket name
String exampleBucket = "example-bucket";
// Obtain the custom domain name of the bucket.
GetBucketCustomDomainRequest getBucketCustomDomainRequest = new GetBucketCustomDomainRequest(exampleBucket);
BucketCustomDomainInfo bucketCustomDomainInfo =
obsClient.getBucketCustomDomain(getBucketCustomDomainRequest);
System.out.println("StatusCode:" + bucketCustomDomainInfo.getStatusCode());
System.out.println("RequestId:" + bucketCustomDomainInfo.getRequestId());
for(BucketCustomDomainInfo.Domains domain : bucketCustomDomainInfo.getDomains()) {
System.out.println("DomainName:" + domain.getDomainName());
System.out.println("CertificateId:" + domain.getCertificateId());
System.out.println("CreateTime:" + domain.getCreateTime());
System.out.println();
System.out.println("GetBucketCustomDomain successfully");
} catch (ObsException e) {
System.out.println("GetBucketCustomDomain failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
// Check all Map entries and print all headers associated with the error.
Map<String, String> headers = e.getResponseHeaders();
if(headers != null){
for (Map.Entry<String, String> header : headers.entrySet()) {
System.out.println(header.getKey()+":"+header.getValue());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
} Helpful Links
