Obtaining the Public Access Status of a Bucket (SDK for Java)
Function
This API obtains the public access status of an OBS bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To obtain the public access status of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketPublicStatus in IAM or GetBucketPublicStatus in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getBucketPublicStatus(GetBucketPublicStatusRequest request )
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for obtaining the public status of an OBS bucket. For details, see GetBucketPublicStatusRequest. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| bucketPublicStatus | Explanation: Public access status of the bucket. Default value: None |
