Help Center/ Object Storage Service/ SDK Reference/ Java/ Bucket APIs (SDK for Java)/ Block Public Access (BPA) (SDK for Java)/ Obtaining the Public Access Status of a Bucket Policy (SDK for Java)
Updated on 2026-08-14 GMT+08:00
Function
This API obtains the public access status of an OBS bucket policy.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.getBucketPolicyPublicStatus(GetBucketPolicyPublicStatusRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
Yes
Explanation:
Request parameters for obtaining the public access status of an OBS bucket policy. For details, see GetBucketPolicyPublicStatusRequest.
Table 2 GetBucketPolicyPublicStatusRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 3 GetBucketPolicyPublicStatusResult
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors).
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
bucketPolicyStatus
BucketPolicyStatus
Explanation:
Public access status of the bucket policy.
Default value:
None
Table 4 BucketPolicyStatus
Type
isPublic
Boolean
Explanation:
Whether the bucket policy is public.
Default value:
None
Code Examples
This example obtains the public access status of the bucket policy of the example-bucket-name bucket.
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.bpa.BucketPolicyStatus;
import com.obs.services.model.bpa.GetBucketPolicyPublicStatusRequest;
import com.obs.services.model.bpa.GetBucketPolicyPublicStatusResult;
import java.util.Map;
public class GetBucketPolicyPublicStatusDemo {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        // String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use a permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        // Use a temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            String bucketName = "example-bucket-name";
            GetBucketPolicyPublicStatusRequest getBucketPolicyPublicStatusRequest =
                new GetBucketPolicyPublicStatusRequest();
            getBucketPolicyPublicStatusRequest.setBucketName(bucketName);
            GetBucketPolicyPublicStatusResult getBucketPolicyPublicStatusResult =
                obsClient.getBucketPolicyPublicStatus(getBucketPolicyPublicStatusRequest);
            BucketPolicyStatus bucketPolicyStatus =
                getBucketPolicyPublicStatusResult.getPolicyStatus();
            if (bucketPolicyStatus != null) {
                Boolean bucketPolicyStatusIsPublic = bucketPolicyStatus.getIsPublic();
                if (bucketPolicyStatusIsPublic != null) {
                    System.out.println("GetBucketPolicyPublicStatus BucketPolicyStatusIsPublic:" + bucketPolicyStatusIsPublic);
            } else {
                System.out.println("GetBucketPolicyPublicStatus bucketPublicAccessBlock is null.");
            System.out.println("GetBucketPolicyPublicStatus successfully");
        } catch (ObsException e) {
            System.out.println("GetBucketPolicyPublicStatus failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            Map<String, String> headers = e.getResponseHeaders();// Check Map entries and print all headers associated with the error.
            if(headers != null){
                for (Map.Entry<String, String> header : headers.entrySet()) {
                    System.out.println(header.getKey()+":"+header.getValue());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
