Deleting the BPA Configuration of a Bucket (SDK for Java)
Function
This API deletes the public access block configuration of an OBS bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To delete the BPA configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucketPublicAccessBlock in IAM or DeleteBucketPublicAccessBlock in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.deleteBucketPublicAccessBlock(DeleteBucketPublicAccessBlockRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for deleting the PublicAccessBlock configuration of an OBS bucket. For details, see DeleteBucketPublicAccessBlockRequest. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example deletes the BPA configuration of bucket example-bucket-name.
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.bpa.DeleteBucketPublicAccessBlockRequest;
import java.util.Map;
public class DeleteBucketPublicAccessBlockDemo {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
// String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
// Obtain an endpoint using environment variables or import it in other ways.
// String endPoint = System.getenv("ENDPOINT");
// Create an ObsClient instance.
// Use a permanent AK/SK pair to initialize the client.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Use a temporary AK/SK pair and security token to initialize the client.
// ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
try {
String bucketName = "example-bucket-name";
DeleteBucketPublicAccessBlockRequest deleteBucketPublicAccessBlockRequest =
new DeleteBucketPublicAccessBlockRequest();
deleteBucketPublicAccessBlockRequest.setBucketName(bucketName);
obsClient.deleteBucketPublicAccessBlock(deleteBucketPublicAccessBlockRequest);
System.out.println("DeleteBucketPublicAccessBlock successfully");
} catch (ObsException e) {
System.out.println("DeleteBucketPublicAccessBlock failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
Map<String, String> headers = e.getResponseHeaders();// Check Map entries and print all headers associated with the error.
if(headers != null){
for (Map.Entry<String, String> header : headers.entrySet()) {
System.out.println(header.getKey()+":"+header.getValue());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
} What is your overall rating for this page?
