Obtaining the BPA Configuration of a Bucket (SDK for Java)
Function
This API returns the public access block configuration of an OBS bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To obtain the BPA configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketPublicAccessBlock in IAM or GetBucketPublicAccessBlock in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getBucketPublicAccessBlock(GetBucketPublicAccessBlockRequest request )
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for obtaining the PublicAccessBlock configuration of a bucket. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| bucketPublicAccessBlock | Explanation: PublicAccessBlock configuration of a bucket Restrictions: None Value range: None Default value: None |
Code Examples
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.bpa.BucketPublicAccessBlock;
import com.obs.services.model.bpa.GetBucketPublicAccessBlockRequest;
import com.obs.services.model.bpa.GetBucketPublicAccessBlockResult;
import java.util.Map;
public class GetBucketPublicAccessBlockDemo {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
// String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
// Obtain an endpoint using environment variables or import it in other ways.
// String endPoint = System.getenv("ENDPOINT");
// Create an ObsClient instance.
// Use a permanent AK/SK pair to initialize the client.
ObsClient obsClient = new ObsClient(ak, sk,endPoint);
// Use a temporary AK/SK pair and security token to initialize the client.
// ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
try {
String bucketName = "example-bucket-name";
GetBucketPublicAccessBlockRequest getBucketPublicAccessBlockRequest =
new GetBucketPublicAccessBlockRequest();
getBucketPublicAccessBlockRequest.setBucketName(bucketName);
GetBucketPublicAccessBlockResult getBucketPublicAccessBlockResult =
obsClient.getBucketPublicAccessBlock(getBucketPublicAccessBlockRequest);
BucketPublicAccessBlock bucketPublicAccessBlock =
getBucketPublicAccessBlockResult.getBucketPublicAccessBlock();
if (bucketPublicAccessBlock != null) {
Boolean blockPublicACLs = bucketPublicAccessBlock.getBlockPublicACLs();
Boolean blockPublicPolicy = bucketPublicAccessBlock.getBlockPublicPolicy();
Boolean ignorePublicACLs = bucketPublicAccessBlock.getIgnorePublicACLs();
Boolean restrictPublicBuckets = bucketPublicAccessBlock.getRestrictPublicBuckets();
if (blockPublicACLs != null) {
System.out.println("GetBucketPublicAccessBlock BlockPublicACLs:" + blockPublicACLs);
if (blockPublicPolicy != null) {
System.out.println("GetBucketPublicAccessBlock BlockPublicPolicy:" + blockPublicPolicy);
if (ignorePublicACLs != null) {
System.out.println("GetBucketPublicAccessBlock IgnorePublicACLs:" + ignorePublicACLs);
if (restrictPublicBuckets != null) {
System.out.println("GetBucketPublicAccessBlock RestrictPublicBuckets:" + restrictPublicBuckets);
} else {
System.out.println("GetBucketPublicAccessBlock bucketPublicAccessBlock is null.");
System.out.println("GetBucketPublicAccessBlock successfully");
} catch (ObsException e) {
System.out.println("GetBucketPublicAccessBlock failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
Map<String, String> headers = e.getResponseHeaders();// Check Map entries and print all headers associated with the error.
if(headers != null){
for (Map.Entry<String, String> header : headers.entrySet()) {
System.out.println(header.getKey()+":"+header.getValue());
e.printStackTrace();
} catch (Exception e) {
// Print other error details.
} Feedback
