Deleting Back-to-Source by Mirroring Rules (SDK for Java)
Function
This API is used to delete back-to-source by mirroring rules of a bucket.
Restrictions
- To delete the back-to-source by mirroring rules of a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteMirrorBackToSource granted using IAM or DeleteMirrorBackToSource granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.deleteBucketMirrorBackToSource(DeleteBucketMirrorBackToSourceRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for deleting the back-to-source by mirroring rules. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Sample Code
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.mirrorback.DeleteBucketMirrorBackToSourceRequest;
public class DeleteBucketMirrorBackToSource {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use.
// Obtain an endpoint using environment variables or import it in other ways.
String endPoint = System.getenv("ENDPOINT");
ObsConfiguration obsConfiguration = new ObsConfiguration();
obsConfiguration.setEndPoint(endPoint);
ObsClient obsClient = new ObsClient(ak, sk, securityToken, obsConfiguration);
try {
String exampleBucket = "examplebucket";
DeleteBucketMirrorBackToSourceRequest request = new DeleteBucketMirrorBackToSourceRequest(exampleBucket);
obsClient.deleteBucketMirrorBackToSource(request);
System.out.println("DeleteBucketMirrorBackToSource successfully");
} catch (ObsException e) {
System.out.println("DeleteBucketMirrorBackToSource failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
} Helpful Links
