Obtaining the Default WORM Policy of a Bucket (SDK for Java)
Function
This API is used to obtain the default WORM policy of a bucket.
If you have never configured the default bucket-level retention policy after enabling WORM for a bucket, you can still use this API to check whether WORM is enabled.
Restrictions
- To obtain the default WORM policy of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketObjectLockConfiguration granted using IAM or GetBucketObjectLockConfiguration granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getObjectLockConfiguration(GetObjectLockConfigurationRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for obtaining the default WORM policy of a bucket. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| objectLockConfiguration | Explanation: WORM policy configuration. For details, see Table 4. |
| objectLockEnabled | String | Explanation: Bucket-level WORM status Value range: Enabled: Bucket-level WORM is enabled. |
| rule | Explanation: Rules of a bucket-level WORM policy. For details, see Table 5. |
| defaultRetention | Explanation: Default bucket-level WORM policy. For details, see Table 6. |
Sample Code
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.objectlock.DefaultRetention;
import com.obs.services.model.objectlock.GetObjectLockConfigurationRequest;
import com.obs.services.model.objectlock.GetObjectLockConfigurationResult;
import com.obs.services.model.objectlock.ObjectLockConfiguration;
public class GetObjectLockConfiguration {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use.
// Obtain an endpoint using environment variables or import it in other ways.
String endPoint = System.getenv("ENDPOINT");
ObsConfiguration obsConfiguration = new ObsConfiguration();
obsConfiguration.setEndPoint(endPoint);
ObsClient obsClient = new ObsClient(ak, sk, securityToken, obsConfiguration);
try {
String exampleBucket = "exampleBucket";
GetObjectLockConfigurationRequest request = new GetObjectLockConfigurationRequest(exampleBucket);
GetObjectLockConfigurationResult result = obsClient.getObjectLockConfiguration(request);
ObjectLockConfiguration config = result.getObjectLockConfiguration();
System.out.println("GetObjectLockConfiguration successfully");
System.out.println("ObjectLockEnabled: " + config.getObjectLockEnabled());
if (config.getRule() != null) {
DefaultRetention retention = config.getRule().getDefaultRetention();
System.out.println("Mode: " + retention.getMode());
System.out.println("Days: " + retention.getDays());
System.out.println("Years: " + retention.getYears());
} catch (ObsException e) {
System.out.println("GetObjectLockConfiguration failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
} Helpful Links
