Deleting Object Tags (SDK for Java)
Function
This API is used to delete tags of an object. For more information about object tags, see Adding Tags to an Object.
If there is no object version ID (indicated by versionId) contained in the request, you must have the DeleteObjectTagging permission. If you specify a version ID in a request, make sure that you have the DeleteObjectTagging and DeleteObjectVersionTagging permissions. By default, only the object owner can perform this operation. The object owner can grant this permission to others by using a bucket policy or a user policy.
OBS deletes tags from the current object version by default. You can use the versionId parameter to delete tags from any other version. If the version is a delete marker, OBS returns 404 Not Found.
Restrictions
This API is not available for parallel file systems.
Method
HeaderResponse deleteObjectTagging(ObjectTaggingRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for deleting object tags. For details, see Table 2. |
Responses
| Method | Return Value Type | Description |
| deleteObjectTagging(ObjectTaggingRequest request) | Results returned for the request to delete object tags. |
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example deletes the tags of object exampleObjectKey in bucket examplebucketname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.ObjectTaggingRequest; public class DeleteObjectTagging001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT") // Create an ObsClient instance. try (ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint)) { // Delete object tags. String bucketName = "examplebucketname"; String objectKey = "exampleObjectKey"; String objectVersionId = ""; ObjectTaggingRequest objectTaggingRequest = new ObjectTaggingRequest(bucketName, objectKey, objectVersionId, null); obsClient.deleteObjectTagging(objectTaggingRequest); System.out.println("DeleteObjectTagging successfully"); } catch (ObsException e) { System.out.println("DeleteObjectTagging failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("DeleteObjectTagging failed"); // Print other error information. e.printStackTrace(); } } } |
