How Do I Specify Content-SHA256? (SDK for Java)
You can upload the x-obs-content-sha256 header when uploading an object or a part. The value of this header is the hexadecimal value converted from the SHA256 value of the request body and is calculated from Hex(SHA256Hash(<payload>). The server calculates and verifies the SHA256 value of the message body in the request with x-obs-content-sha256 included, which may make performance deteriorate, but is recommended for security purposes. Sample code for uploading an object is as follows:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.PutObjectRequest; import java.io.File; import java.io.InputStream; import java.nio.file.Files; import java.security.MessageDigest; public class PutObjectWithSha256 { public static void main(String[] args) { // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. Here uses CN North-Beijing4 as an example. Replace it with the one in use. // Obtain an endpoint using environment variables or import it in other ways. // String endPoint = System.getenv("ENDPOINT"); String endPoint = "https://obs.cn-north-4.myhuaweicloud.com"; // Create an ObsClient instance. try (ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint)) { // This example uploads a local file to a bucket, with the content-sha256 header specified. String bucketName = "examplebucket"; String objectKey = "exampleObjectKey"; File localFile = new File("localFilePath"); PutObjectRequest putObjectRequest = new PutObjectRequest(); putObjectRequest.setBucketName(bucketName); putObjectRequest.setObjectKey(objectKey); putObjectRequest.setFile(localFile); // Calculate SHA256 of the file. InputStream fis = Files.newInputStream(localFile.toPath()); byte[] buffer = new byte[1024]; MessageDigest sha256 = MessageDigest.getInstance("SHA-256"); for (int numRead = 0; (numRead = fis.read(buffer)) > 0; ) { sha256.update(buffer, 0, numRead); } fis.close(); // Convert the SHA256 value to a hexadecimal number. StringBuilder sha256Builder = new StringBuilder(); for (byte aB : sha256.digest()) { sha256Builder.append(String.format("%02x", aB)); } // Add the SHA256 to the user-defined header. putObjectRequest.addUserHeaders("x-obs-content-sha256", sha256Builder.toString()); obsClient.putObject(putObjectRequest); System.out.println("PutObjectWithSha256 successfully"); } catch (ObsException e) { System.out.println("PutObjectWithSha256 failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the detailed error information. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("PutObjectWithSha256 failed"); // Print other error information. e.printStackTrace(); } } } |
OBS SDK for Java supports integrity check with both MD5 and SHA256 (SHA256 is recommended for its higher security).
