Does the SDK Support Uploading, Downloading, or Copying Objects in a Batch? (Java SDK)
No.
Currently, the SDK does not provide such APIs. You need to encapsulate the service codes for uploading, downloading, or copying objects in a batch by yourself. The procedure is as follows:
- List all objects to be uploaded, downloaded, or copied. For details about how to list objects to be downloaded, see Listing Objects (SDK for Java).
- Call the API for uploading, downloading, or copying a single object for the listed objects.
Sample code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 | // Replace the following region with the one in use. CN-Hong Kong is used here as an example. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); final String bucketName = "bucketname"; // Define the prefix of objects in a bucket. final String objectPre = "object/"; // Folder to be uploaded final String localDirPath = "localDirPath"; final List<File> list = new ArrayList<>(); // Scan all objects in the folder. static void listFiles(File file){ File[] fs = file.listFiles(); assert fs != null; if (fs.length < 1){ // If an empty folder needs to be uploaded, add it to the list. list.add(file); }else{ for (File f:fs){ if (f.isDirectory()){ listFiles(f); } if (f.isFile()){ // Add objects to be uploaded to the list. list.add(f); } } } } // Traverse the folder to be uploaded and obtain all objects to be uploaded. File file = new File(localDirPath); listFiles(file); // Create an instance of ObsClient. final ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Initialize the thread pool. ExecutorService executorService = Executors.newFixedThreadPool(20); // Concurrently upload parts. for (File f:list){ executorService.execute(() -> { if (f.isDirectory()){ // For empty folders, create empty folder objects in the bucket. String remoteObjectKey = objectPre + f.getPath().substring(localDirPath.length() + 1) + "/"; obsClient.putObject(bucketName, remoteObjectKey, new ByteArrayInputStream(new byte[0])); }else{ String remoteObjectKey = objectPre + f.getPath().substring(localDirPath.length() + 1); obsClient.putObject(bucketName, remoteObjectKey, new File(f.getPath())); } }); } // Wait until the upload is complete. executorService.shutdown(); while (!executorService.isTerminated()) { try { executorService.awaitTermination(5, TimeUnit.SECONDS); } catch (InterruptedException e) { e.printStackTrace(); } } // Close ObsClient. try { obsClient.close(); } catch (IOException e) { e.printStackTrace(); } |
You can use multiple threads to concurrently upload, download, and copy data to improve efficiency.
