How Do I Download an Encrypted Object Using a URL? (Java SDK)
If the object is encrypted with SSE-KMS, the server automatically decrypts the object when you use the URL of the object to download it.
If the object is encrypted with SSE-C, you cannot access the object directly through a web browser because a request header is required for decryption. If you use code to download the encrypted object, configure the header by referring to Code Example: Downloading an Object Encrypted Using SSE-C.
  Accessing a server-side encrypted object requires the HTTPS protocol.
