Help Center/ Object Storage Service/ SDK Reference/ Java/ Bucket APIs (SDK for Java)/ Static Website Hosting (SDK for Java)/ Obtaining Static Website Hosting Configurations (SDK for Java)
Updated on 2026-08-14 GMT+08:00
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
  • Redirecting all requests to another website
  • Redirecting specific requests to another website
This API returns the static website hosting configurations of the bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.getBucketWebsite(final BaseBucketRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
BaseBucketRequest
Yes
Explanation:
Request parameters for obtaining the hosting configuration. For details, see Table 2.
Table 2 BaseBucketRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 3 WebsiteConfiguration
Type
Mandatory (Yes/No)
suffix
String
No
Explanation:
Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket.
Value range:
This parameter can neither be left blank nor contain slashes (/).
Default value:
None
key
String
No
Explanation:
Object name to use when a 4XX error occurs. This parameter specifies the web page to display when an error occurs.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
redirectAllRequestsTo
RedirectAllRequest
No
Explanation:
Redirection rules for all requests. For details, see Table 4.
routeRules
List<RouteRule>
No
Explanation:
List of routing rules. For details, see Table 6.
Table 4 RedirectAllRequest
Type
Mandatory (Yes/No)
hostName
String
Yes
Explanation:
Host name used for redirection, for example, www.example.com.
Restrictions:
The host name must comply with the host name rules.
Default value:
None
protocol
ProtocolEnum
No
Explanation:
Protocol used for redirection.
Value range:
See Table 5.
Default value:
None
Table 5 ProtocolEnum
Constant
Default Value
HTTP
http
HTTP protocol used for redirection.
HTTPS
https
HTTPS protocol used for redirection.
Table 6 RouteRule
Type
Mandatory (Yes/No)
condition
RouteRuleCondition
No
Explanation:
Conditions of a redirection rule. For details, see Table 7.
redirect
Redirect
Yes
Explanation:
Details about the redirection. For details, see Table 8.
Table 7 RouteRuleCondition
Type
Mandatory (Yes/No)
keyPrefixEquals
String
No
Explanation:
Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect.
For example, to redirect the requests for the object ExamplePage.html, set keyPrefixEquals to ExamplePage.html.
Restrictions:
This parameter cannot be used together with httpErrorCodeReturnedEquals.
Value range:
Default value:
None
String
No
Explanation:
HTTP error code for the redirection to take effect. If there is an error, and the error code returned is the same as the value specified for this parameter, the redirection rule takes effect.
For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set httpErrorCodeReturnedEquals to 404 in RouteRuleCondition, and set replaceKeyWith to NotFound.html in Redirect.
Restrictions:
This parameter cannot be used together with keyPrefixEquals.
Value range:
See Error Codes.
Default value:
None
Table 8 Redirect
Type
Mandatory (Yes/No)
Protocol
ProtocolEnum
No
Explanation:
Value range:
See Table 5.
Default value:
None
hostName
String
No
Explanation:
Host name used for redirection.
Default value:
None
replaceKeyPrefixWith
String
No
Explanation:
Object name prefix used in the redirection request.
Restrictions:
This parameter cannot be used together with replaceKeyWith.
Value range:
Default value:
None
replaceKeyWith
String
No
Explanation:
Object name used in the redirection request.
Restrictions:
This parameter cannot be used together with replaceKeyPrefixWith.
Value range:
Default value:
None
httpRedirectCode
String
No
Explanation:
HTTP status code in the response to the redirect request. For details, see Status Code.
Default value:
None
Code Examples
This example returns the website configuration of bucket examplebucket using obsClient.getBucketWebsite.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.RouteRule;
import com.obs.services.model.WebsiteConfiguration;
public class GetBucketWebsite001
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use a permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        // Use a temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // View the website configuration of the bucket.
            WebsiteConfiguration config = obsClient.getBucketWebsite("examplebucket");
            System.out.println("Key:" + config.getKey());
            System.out.println("Suffix:" + config.getSuffix());
            for(RouteRule rule : config.getRouteRules()){
                System.out.println("rule:" +rule);
            System.out.println("getBucketWebsite successfully");
        } catch (ObsException e) {
            System.out.println("getBucketWebsite failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
