Updated on 2026-09-10 GMT+08:00
Configuring a CORS Rule (SDK for Java)
Function
Cross-origin resource sharing (CORS) is a mechanism defined by the World Wide Web Consortium (W3C) that allows a web application program in one domain to access resources located in another one. For general web page requests, website scripts and contents in one domain cannot interact with those in another because of Same Origin Policies (SOPs). OBS supports CORS rules that allow the resources in OBS to be requested by other domains.
You can call obsClient.setBucketCors to configure CORS rules for a bucket. The configured CORS rules follow the principle of new ones overwriting old ones.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.setBucketCors(final SetBucketCorsRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
Yes
Request parameters for setting a CORS rule. For details, see Table 2.
Table 2 SetBucketCorsRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
bucketCors
BucketCors
Yes
Explanation:
List of CORS rules of a bucket. For details, see Table 3.
Table 3 BucketCors
Type
Mandatory (Yes/No)
rules
List<BucketCorsRule>
Yes
Explanation:
List of CORS rules of a bucket. For details, see Table 4.
Table 4 BucketCorsRule
Type
Mandatory (Yes/No)
id
String
No
Explanation:
CORS rule ID.
Value range:
The value must contain 1 to 255 characters.
Default value:
None
allowedMethod
List<String>
Yes
Explanation:
The allowed HTTP methods for a cross-origin request, indicating the operation types for buckets and objects.
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
allowedOrigin
List<String>
Yes
Explanation:
The origin from which the requests can access the bucket.
Restrictions:
Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com.
Default value:
None
allowedHeader
List<String>
No
Explanation:
The allowed cross-origin request headers. Only CORS requests matching the allowed headers are valid.
Restrictions:
Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
maxAgeSeconds
int
No
Explanation:
Duration your client can cache the response for a cross-origin request.
Restrictions:
Each bucket CORS rule can contain only one maxAgeSeconds.
Value range:
An integer greater than or equal to 0, in seconds.
Default value:
100
exposeHeader
List<String>
No
Explanation:
The CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to the list of the allowed additional headers.
Restrictions:
Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed.
Default value:
None
Responses
Table 5 Common response headers
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Code Examples
This example configures CORS rules for bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.BucketCors;
import com.obs.services.model.BucketCorsRule;
import java.util.ArrayList;
import java.util.List;
public class SetBucketCors001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use a permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        // Use a temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            //Configure CORS rules.
            BucketCors cors = new BucketCors();
            List<BucketCorsRule> rules = new ArrayList<BucketCorsRule>();
            BucketCorsRule rule = new BucketCorsRule();
            ArrayList<String> allowedOrigin = new ArrayList<String>();
            // Specify the origin of the cross-origin request.
            allowedOrigin.add( "http://www.a.com");
            allowedOrigin.add( "http://www.b.com");
            rule.setAllowedOrigin(allowedOrigin);
            ArrayList<String> allowedMethod = new ArrayList<String>();
            // Specify the request method, which can be GET, PUT, DELETE, POST, or HEAD.
            allowedMethod.add("GET");
            allowedMethod.add("HEAD");
            allowedMethod.add("PUT");
            rule.setAllowedMethod(allowedMethod);
            ArrayList<String> allowedHeader = new ArrayList<String>();
            // Specify whether headers specified in Access-Control-Request-Headers in the OPTIONS request can be used.
            allowedHeader.add("x-obs-header");
            rule.setAllowedHeader(allowedHeader);
            ArrayList<String> exposeHeader = new ArrayList<String>();
            // Specify response headers that users can access using application programs.
            exposeHeader.add("x-obs-expose-header");
            rule.setExposeHeader(exposeHeader);
            // Specify the browser's cache time of the returned results of OPTIONS requests for specific resources, in seconds.
            rule.setMaxAgeSecond(10);
            rules.add(rule);
            cors.setRules(rules);
            obsClient.setBucketCors("examplebucket", cors);
            System.out.println("setBucketCors successfully");
        } catch (ObsException e) {
            System.out.println("setBucketCors failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
